Old 05-14-2020, 02:47 PM
Lux Wrangler Lux Wrangler is offline
Default Slick T-150 ?E? Gap Gauge
I am looking to borrow, or buy, a Slick magneto T-150 ?E? Gap Gauge around Petaluma airport O69.
Jim Peck
San Francisco Bay Area
RV-7
Old 05-17-2020, 08:13 PM
Default T-150 tool
Can someone accurately measure the thickness and overall length of the T-150 tool? Is it steel?
Jim Peck
RV-7
Old 05-17-2020, 08:48 PM
rocketbob's Avatar
You can set the egap without the tool. Line the notches up visually.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 05-17-2020, 10:45 PM
lr172 lr172 is offline
1/16” Al. Length does not matter, but the dimensions of the small step area and the offset do. I made one by looking at a picture and reworking it until it fit. The 1/16” dimension is he key for the gap. The tool slips in the slot of the armature and hits the case step/shelf. Ponts should open exactly at that position.
Old 05-18-2020, 07:51 AM
Default T-150 e gap tool
1/16? Al. Length does not matter, but the dimensions of the small step area and the offset do. I made one by looking at a picture and reworking it until it fit. The 1/16? dimension is he key for the gap. The tool slips in the slot of the armature and hits the case step/shelf. Ponts should open exactly at that position. lr172
Thank you. That is very helpful. By having the overall dimension of an original tool, I hope to scale the small step and offset from the picture...rather than iterate.
Jim Peck
RV-7
