05-17-2020, 12:38 PM
Buller dies
Originally Posted by RudysRV7
What is meant by "set of dies"? Interested.
https://bullerent.com/experimental/longeron-dies/
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
05-17-2020, 09:46 PM
Thanks PhatRV, sounds simple. I like the idea of buying the templates from Home Depot.
Say, What size does the DWG come in from Vans, that has the actual scale of the bend?
I am hoping to print this DWG out, prior to getting the fuselage kit.
05-17-2020, 09:48 PM
Thanks for the link wirejock. Seems well worth the investment.
05-18-2020, 08:16 AM
DWG
There should be a full scale drawing in the kit.
However, you won't be riveting the paper so don't quit till you use the actual parts to compare the bends. Especially the downward bend that matches the side skin.
Larry Larson
Estes Park, CO
Disclaimer
05-18-2020, 11:07 AM
Draker - Thanks for sharing your mistake. I can see how is something I would have done.
Hope all is well in Livermore. I am originally from Modesto, CA. (where I built the wings and empennage.
Cheers
05-19-2020, 07:33 AM
The paper drawing is not full size. If you measure the bend locations as noted in the plan, the longerons will come out perfect. You need to make the mark before you make the bend. Some people clamp both longerons to keep them in symmetry. I bended one longeron at a time and both came out in symmetry as well. I found this is easier to whack it with a heavy mallet without have to worry about hitting the opposite longeron.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Started
Avionics Installation -- Bench tested
Firewall Forward -- New engine received !
Electrical -- After engine installation
Donation paid through 2020
05-30-2020, 05:20 PM
Dont stress about it...just go slowly
Just take your time....mine worked out fine with just a vice and rubber mallet. If you want, get some cheap angle form the hardware store and practice the bends on a short piece to get the feel for how it goes...
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
