Old 05-12-2020, 02:43 PM
Caummisar's Avatar
Caummisar Caummisar is offline
Talking Safety Wire Screw Clamps
While looking at a builder's website, I notice he/she had safety wired SS screw clamp screws. Is that standard practice? If yes, then why didn't I know?
https://www.flickr.com/gp/188428474@N06/Rq761v
VAF# 835
RV-7A /FWF/Glued canopy
Slow build --- ALL THE WAY
Victim of SB-632-B
2022 Dues Happily Paid
Old 05-12-2020, 02:58 PM
scard's Avatar
scard scard is offline
Way back in the beginning I did. I haven't found the need since. I'm not sure who I thought I was going to impress . Oh, I guess there was that OSH judging thing.
Scott Card
CMW E-Lift
VAF Advertiser
Old 05-12-2020, 07:03 PM
OZCleco's Avatar
OZCleco OZCleco is offline
Default Perhaps an airline A&P?
If memory serves me correctly for the older airframes, this was standard practice on P3, FA18 and A320 pneumatic systems, although those clamps were a completely different heavy duty type design.
If I still had access to airbusworld I'd have a quick look at the AMM to confirm.
I've kept that up on our RV9A / O-320, validated by finding multiple loose clamps on initial receipt of the aircraft.
Whatever gives you confidence to fly over long stretches of water, and it's a safe practice regardless.
(Coming from the airline world I was gobsmacked to see what is and isn't safetied. It's like working on tractors)
Pat.
Old 05-12-2020, 07:40 PM
bjdecker's Avatar
bjdecker bjdecker is offline
I've wondered about the need -- couple of thoughts:
Not all clamps are created equal. Note the difference in the shape of the slots cut in the band -- genuine Breeze Aero-seal clamps are "D" shaped which matches the profile of the screw much better than other clone clamps.
see https://www.aircraftspruce.com/catal...ges/qs100h.php and https://www.aircraftspruce.com/catal...s/15-06060.php for comparison.
Most fasteners that should be wired have a hole drilled in the head or shank ("Put wire here...") -- running the wire over the slot seems to be a solution looking for a problem.
So, unless you really like safety wire, poking/scratching yourself - I'd leave it off.
Just my opinion - I'm not an expert.
B
Brian Decker
RV-7 (Flying)
Old 05-12-2020, 07:57 PM
9GT's Avatar
9GT 9GT is offline
Years ago my buddy had one vibrate loose on the exhaust heat muff on the Cozy MKIV. We found it during a condition inspection. If it had come fully off, it would have gone right through the prop, so I safety wired most of the worm clamps on the RV-10 "just in case". Not sure I will bother on the 9A.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 05-12-2020, 09:38 PM
JDeanda JDeanda is offline
I had a hose clamp on the Vetterman exhaust system come loose on our RV-6, so I safety wired it. I’d never seen a worm-drive hose clamp with safety wire on it before, but it stayed tight. I suppose it came loose because it ran so hot and then cooled back to room temp over and over. I’ve since redesigned that connexion with a different clamp, so no more problems. But I’ve never had a problem with the ones on the Lycoming intake tubes.
Old 05-13-2020, 06:27 AM
Rick_A's Avatar
Rick_A Rick_A is offline
If you are doing a thorough check FWF every time you change the oil, I don?t see the need for safety wire on clamps.
I include checking clamps as part of my regular maintenance at every oil change, which I do at 25 hours. Nothing fancy, I just put a screwdriver or nut driver on them and snug them up if they need it.
My only exception is the clamp the secures my purge valve cable to the bracket. I have safety wire on that clamp. In this case the wire acts as a backup to the clamp itself.
Rick Aronow,
Flying 7A Slider;
RV-12 SOLD
Jacksonville, FL
Old 05-13-2020, 06:40 AM
noelf noelf is offline
The only hose clamps I have safety wired are the ones holding the EGT probes.
Noel
RV-6A N6NF
tip-up
flying
Old 05-13-2020, 07:02 AM
Saville's Avatar
Saville Saville is offline
I safety wire mine.
Flying RV-8 N880BC
2021 Dues - happily paid.
Old 05-13-2020, 09:37 AM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
Originally Posted by Saville View Post
I safety wire mine.
+1. I do the same.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
