Old 05-11-2020, 03:07 PM
Felipemg Felipemg is offline
Default New to taildraggers
I just solo'd on my RV4 (N7071J) and I'm new to tail-draggers, 1,400 hr private IFR used to fly a Piper Malibu where my approach and landing speeds were much higher.
I'm amazed of how slow you have to get in order to actually touch on all 3 wheels and I'm slowly getting used to these new parameters.
I've seen on this forum that there are 2 lines of thought on this issue, some argue to land on the mains then to slow down to lower the tail while the other argue to land on 3 even on x-wind conditions.
So far I've landed in nothing but calm conditions and 3 wheel landings, close to stall speed, have been relatively easy to learn but if feels a little exposed in the case of gusty x-wind conditions.
Can anyone share their experience on this subject to further my learning
Thank y'all for your help
Blessings
Felipe
https://flightaware.com/photos/view/...rcrafttype/RV4
Old 05-11-2020, 03:54 PM
Bicyclops Bicyclops is offline
Check out the EAA webinar:
https://www.eaa.org/Videos/Webinars
Mike Seager recommends 3 pointers first, then look at wheel landings later.
Ed Holyoke
Old 05-11-2020, 04:09 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF
Felipe, welcome aboard the good ship VAF
RV4---jealous, I am.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-11-2020, 04:18 PM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Good pointer from Ed.
Another one, runway < than say 1200’ = 3 pointers = shorter roll out.
> than say 1200” (or whatever, meaning for me it’s closer to 1K) choose whatever suits u. Basically I always 3point since it is what I learned first and runways can be pretty short around here...
In a nutshell, don’t set your approach speed to your ego, but on your aircraft characteristics, and those RVs fly surprisingly slow
Life's short... Enjoy!
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 05-11-2020, 05:03 PM
Mel's Avatar
Mel Mel is offline
The short-wing RVs have a high enough wing loading and sit so low to the ground that cross winds are not a problem even in a 3-point. I 3-pointed my -6 about 95% of the time. My runway is 1500' long@640' elevation and I seldom had to use brakes.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-11-2020, 05:41 PM
Pilot8 Pilot8 is offline
Mike Seager gave an EAA webinar earlier this weeked titled "Critical RV Flying Skills" that you might find insightful.
Old 05-11-2020, 06:59 PM
swjohnsey swjohnsey is offline
Originally Posted by RV8JD View Post
Here are some articles by Van himself that may be of interest:
Articles: "How to Fly an RV", "How to Land an RV", and "How to Land an RV, Part 2".
Also, "The Compleat Taildragger Pilot" is a great book on flying taildraggers.
Part 2 mentions slow flying down the runway. I used this technique to help with wheel landing. I would fly down the runway at 75 - 80 mph in the RV-4 trying to keep the wheels just off. At some point the wheels will kiss and you have landed. Find a nice long runway.
Old 05-11-2020, 08:48 PM
Here's a small tip that I've found helpful. On base or final, I wiggle my ankles. Sort of reminds them that I might need them and tells 'em to wake up.
Dave
Old 05-12-2020, 12:33 AM
Shimoda Shimoda is offline
I prefer to 3-point my RV4, & find the wheel landing more difficult (..to achieve consistency).
I work to a 15kt x-wind personal limit, but have had no problem with x-wind 15G25kt... If I think it might be 'challenging' (as this case) I prefer the grass runway.
I always remember guidance from the guy who originally did my conversion training... his point was :
1)RVs have great control authority, even at stall speed, and
2) the tail has to come down sometime...better to touch-down 3-point at minimum speed, than wheel on, only to ground-loop when the tail comes down !
Just my 2c
PS - In a strong/gusty x-wind I also tend to select half-flap ? but I think that's more habit than anything, as I cant really feel much difference in roll-response, between that & full-flap
Old 05-12-2020, 05:10 AM
Stoppel Stoppel is offline
Default Wheel landing
My RV4 seemed best when three pointing however my 8 does not seem to and I wheel land 99% of the time. In short do what the airplane feels best at. I prefer wheel landing because it gives more consistent rudder practice upon landing rollout. Agree with David Paule, my instructor always said the same thing on final, ?wake them feet up?
James Stoppel
RV8 Purchased Flying
