Old 05-06-2020, 09:08 AM
Kooshball Kooshball is offline
Default Photos of Engine mounted oil cooler exits??
I am curious to see some photos of what folks have done with the exit of oil coolers mounted behind the rear cylinder on an installation with plenums vs baffling. I have been reading about diffusers, ducting via scat, ?do nothing?, etc am looking for best practices.
Thx
Old 05-06-2020, 11:15 AM
Raymo's Avatar
Raymo Raymo is offline
Mine (w/ plenum) is mounted behind the #4 cyl with nothing for ducting. I have to cover about a quarter of the cooler, even in the summer Georgia heat, to keep temps around 180-200.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 05-06-2020, 11:18 AM
Ralph Inkster Ralph Inkster is offline
Suggest mount it per the FWF plans for now, and only IF you have issues, look into specialty modifications/ducting/louvers etc. Oil cooler should work the same with either closed plenum or stock baffle system.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 05-06-2020, 05:15 PM
RV7 To Go's Avatar
RV7 To Go RV7 To Go is offline
Thx
I mounted mine as per the drawings and like many others found the baffles starting to crack after 50 hrs in the corner behind #4 cyl. I modified the baffles as per many posts. I then found cracks in the cooler mounting flanges. I mounted the new cooler from the engine mount and fabricated some glass transition ducts using 4" SCAT to connect. No cooling or cracking issues in the 250 hrs since the mod. Sorry no photos but there many posts with pics showing different mods.
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
RV4 - Built 2021 Time flown and Sold
Old 05-06-2020, 07:11 PM
bhester's Avatar
bhester bhester is online now
Thumbs up Just rebuilt mine
Yes, I also have a oil cooler shutter installed
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2020 VAF donator - alot better than any magazine subscription
Old 05-07-2020, 06:56 PM
John RV8 John RV8 is offline
Default Oil Cooler exit
Mine is mounted per the plans behind the #4 cylinder. With the louvre style airflow control. No ducting for the exit air. The louvers block some airflow even when fully open, but temps are never 210 even on a slow (for an RV) speed climb on a HOT Texas summer day.
Sorry, No picture.... it looks like most other RV?s 😎
John Goodloe
RV-8. N6279G
Pay in November
Old 05-08-2020, 06:02 AM
Capflyer's Avatar
Capflyer Capflyer is offline
This was my last RV8 build using the larger SW oil cooler and using a plenum. It requires a larger hole in the rear baffle as well. Mounted it lower on the rear baffle at an angle which allows plenty of cooling on cyl 4 without scavenging its cooling air. 200 hours so far an no issues. My other RV8 has the stock Van's oil cooler mounted on the firewall ducted from the rear baffle behind cyl 4. That engine also has a plenum. Either way works fine but I like having a cleaner firewall look. No issues with engine cooling or oil temps on either plane.
https://photos.app.goo.gl/xKTT3onyE3FmavPd9
Mike
RV4/HRII Hybrid - Building
RV8 Hot Rod "Drone Killer" - Flying
RV8 Blue Nose "Look'n Good" - Flying
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 05-08-2020, 09:08 AM
Edwardoc Edwardoc is offline
From my Build Photos. My baffles cracked on both sides so I reinforced both sides with angle.
https://edwardoconnor.smugmug.com/RV...xK/i-M5PZdW7/A
https://edwardoconnor.smugmug.com/RV...xK/i-rpcmdZD/A
https://edwardoconnor.smugmug.com/RV...xK/i-gM4bVtX/A
https://edwardoconnor.smugmug.com/RV...xK/i-vTcjFWC/A
Old 05-08-2020, 10:59 AM
Originally Posted by Capflyer View Post
This was my last RV8 build... ...Either way works fine but I like having a cleaner firewall look. No issues with engine cooling or oil temps on either plane.
But the firewall treatment does add to the 'COOL' effect!
Ralph
Old 05-09-2020, 05:54 AM
How far up does the rear baffle go behind the #4 cyl in your installation?
