  #21
Old 05-07-2020, 10:09 AM
rvbuilder2002's Avatar
Originally Posted by NinerBikes View Post
Supposedly 5 to 7 kt's depending on who you talk to. rgawer did a write up about the cumulative effects a while back.
On the RV-12 with the speeds it flys at the difference of wheel pants and nose gear leg fairing, or not, is 3 kts.
Max cruise with is 120 Kts
Max cruise without is 117 Kts
Scott McDaniels
Hubbard, Oregon
Old 05-07-2020, 05:11 PM
Piper J3's Avatar
Piper J3 Piper J3 is online now
Main advantage is there are cool looking and keep bottom of airplane clean. The fairings are very robust design and remain solidly attached even when operating exclusively from turf runway.
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 05-07-2020, 06:48 PM
pilotkms's Avatar
pilotkms pilotkms is offline
I used skybolt 1/4 turns on all 3 of my wheel pants. No screws. 500 hours and 400+ landings - no issues. Can remove all 3 in LESS than 5 minutes. And replace in LESS than 5 minutes also. Looks exactly like screws.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
550+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
Old 05-07-2020, 06:54 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Could you post or email me some pictures please? Do you have pictures on another personal website or somewhere to see them?
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 05-07-2020, 07:08 PM
I'd like to see them, too.
Dave
Old 05-08-2020, 04:52 AM
Jetmart Jetmart is offline
Pics in another thread
http://www.vansairforce.com/communit...d.php?t=182184
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Received RV-14 Empennage Kit October 22, 2019
Started Tail Cone Dec 2019
Received QB Kit April 2020
Finished a mounted Tail Surfaces to Fuselage June 2020
2020 Dues Paid
Old 05-08-2020, 07:50 AM
pstraub's Avatar
pstraub pstraub is offline
Originally Posted by John-G View Post
Paul ... I like your idea about using the bluetooth FOBO trike tire monitors. I looked those up and the set of three costs $148 ... only $25 more than a set of three Camloc access doors.
Hi John, I ordered the FOBO trike set, should be here Monday (from Malaysia). I will let you know how they fit and work. It was worth taking a chance to me, if they don't fit, I will install them on my Suzuki GSXR and have a spare! I also love the idea of the Skybolt fasteners for the wheel pants. That would be the best of all worlds to me, a simple way to check tire pressures via bluetooth.....and if you need to add air, the 1/4 turn fasteners give you access in a few minutes (even just to check brake lines/pads/etc).
Warning, thread drift, I also used your blog post to help me install the Reiff 150W preheat system on my 912ULS last week. I went to my hangar at midnight a few nights ago and plugged it in, came back at 0630 and turned on master. Oil temp was 110 and CHT/EGTs were just in the green. For reference, inside hangar temp overnight was about 50F. Had only a large moving blanket draped over top cowl. Love it!
Paul Straub, First Flight May 5, 2017
N917PB, SN 120971
175 hours and counting.....
