05-31-2007, 10:15 AM
Handheld radio recommendations
Please give me any recommendations on handhelds, or any negatives. Thanks in advance.
Tammy
05-31-2007, 11:00 AM
Tammy
None of them are going to work perfectly. They all will have comparable RF performance. Differences will be in audio strength / clarity, interface, features.
I used a Icom A24, which has the built-in VOR rx. It works fine, comes with a decent interface, accessories, etc. It could be smaller, but small radios typically have bad interfaces - buttons are too small.
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
05-31-2007, 11:07 AM
I'm happy with my Sporty's but have never used the com transmit, just recieve and the VOR. Works well.
I pick up ground control from the tower 3 miles from my home. Air reception would obviously be much better too but haven't tested it specifically.
05-31-2007, 12:44 PM
handheld
i have a vertex. works great. i opted for the model without the vor, 'cuz i have not seen those perform well, and anyway a handheld gps is much better. i was really impressed on how long the vertex battery holds a charge (having had not-so-good performance out of other rechargeables).
i don't think you can go wrong with either icom or vertex. they're both fine radios. if you intend to use it in the cockpit, you would be well-advised to add an external antenna (or a bnc quick-connect to one of the existing comm antennas.) the rubber duckies aren't too efficient.
mho,
john
john prickett (VAF 449)
manchaca, tx (suburb of austin)
rv-7a finish kit
N337JP (reserved)
05-31-2007, 12:59 PM
sportys
works great, mostly use in the pos 150 i fly in . it will pick up ATIS and approach from inside my house (staticy but usable)which is 12 miles from the airport. the land is flat here. lots of woods.its not a busy airport so i havent heard any other stuff. i really like it but havent used anything else. batteries seem to go a good while. holds 8
William Weesner/ still kicking.
05-31-2007, 02:17 PM
I've had 3 different models of ICOM (A-22, A-23, A-6). All performed very well on the Comm functions. I've only had one REAL occasion where I needed to use one in flight and using the handheld antenna and headset adapter I thought the reception and transmission was great. VOR/LOC nav functionality was always marginal at best (A-22 & A-23) even within a few miles of the station with clear line of site and a few thousand feet of altitude. I originally "upgraded" to the A-23 because of its size but that was also a drawback - buttons seemed to be too small and close together for reasonable use inflight. I had an opportunity to trade for a brand new, comm only A-6 and took it. The limited testing I've done shows that it's on par with the other units for clarity and range.
Bob
RV-10 #40105
05-31-2007, 03:32 PM
Range
This week I had to use my Sporty's JD 200 and it got me into and out of a controlled airport but the range seems to be around 20-25 miles and I couldn't raise Center for flight following but heard him trying to call me since he knew I was coming. Glad I had it.
Regards,
Pierre
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
05-31-2007, 05:41 PM
I love my ICOM
Have used an older ic-?? as the only means of communication in my cessna for 15 years and have never had any problems with it whatsoever. This includes thousands of hours of pipeline patrol during which I needed it to talk to various towers. I am not even seriously considering a panel mount radio in my 6.
05-31-2007, 09:12 PM
ICOM A-22 > Sporty's
Mo' expensive. Much better.
1) ANL - noise limiting is much better. Driving in the car with both, the A-22 is quiet until receiving. The Sporty's unsquelches with any apprciable ignition noise and you get an audible tachometer. Haven't flown with the Sporty's.
2) RANGE - Yakking with the test pilot on a first flight, we all had our radios out. Lost contact with the Sporty's. Spooky. Keyed the A-22 'Tom, you still up there?' Reply: 'Yup!'.
Back when I was flying more than building, I would use the A-22 now and then for a radio test. Rubber-ducky antenna and no headphones, like it would be in an emergency. Center always replied and said comms were OK.
3) UTLITY - Used the A-22 exclusively on the last leg of an Angel Flight into DFW (IFR in VMC) after the poor controllers were getting hammered with a nasty squeal every time I hit the TX button in a renter-beater Cherokee. After begging me to stop transmitting (as in 'Say: cancel IFR') they were happy with the handheld/rubber-ducky.
The problem was a bad alternator condenser; it doesn't take complete electrical failure to make a handheld useful..
Caveat:
Use the Alkaline battery pack instead of the NiCads. Mine failed early as did the ICOM replacement. Cell failure. I had the pack rebuilt by a real NiCad house but don't trust it. The charger is mickey mouse. And NiCads are a lousy choice for a backup application anyway.
Hope this helps.
John
John Oldenkamp
RV-7A project for sale
VAF Paid 2018
06-01-2007, 09:34 AM
I use an Icom A-24 and love it.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
