Old 06-06-2020, 11:51 AM
cccjbr6 cccjbr6 is offline
Is the large O ring the only part you lubricate with the Krytox What, if anything, do you use on the latch pin and post?
Chris Kimble
Birmingham Alabama
RV-6A Bluebird- Beautifully built by Bob Axsom and maintained by Vic Syracuse
$10/month donation gratefully made (worth every penny and painless)
Old 06-06-2020, 02:02 PM
RV7 To Go RV7 To Go is offline
I put a light coat on both o-rings and the post. It does not require much and lasts a long time. Mine are 3 years and about 500 fillups old and still work smoothly.
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
Old 06-06-2020, 02:15 PM
rvbuilder2002's Avatar
Closing resistance is reduced by also applying a small amount of lube to the cam portion (at the bottom) of the latch lever.
Scott McDaniels
Hubbard, Oregon
Old 06-06-2020, 04:04 PM
NewbRVator NewbRVator is offline
Default Anyone know the ID/OD
Anyone know the ID/OD for the large viton O-rings for the 6A gas caps?
Thanks.
20 dues paid member since 2018
RV6A
