Old 04-30-2020, 12:29 PM
JDeereGn JDeereGn is offline
Default GRT150 Sport oil pressure sender
I have two part numbers for the oil pressure sending unit. HPS-01 and VDO 360-004. Does anyone know which is correct for GRT150 sport? Tks
Old 04-30-2020, 12:50 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
My first GRT setup had the VDO unit, as I recall it is a simple resistance device, ground through the case, and one wire to the EIS.
My new project has the newer senders, they are higher pressure and look to be a better overall construction. Three wire units, need ground, power and signal hookups. Be careful of what power source ---- the instructions go into detail about that.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
