Old 05-30-2007, 04:22 PM
jmbaute jmbaute is offline
Default Fixing the 'dimple-8'
The story starts out like this:
Newbie gets his new pneumatic squeezer, and makes about 30 great dimples before screwing up.
You guessed it, I punched an extra hole right by the one it was intended for in the HS skin. This is where the inboard leading edge rib will mate to the skin.
I've lurked here long enough to know this is no big deal. I decided to drill it out to a #30. The problem is, the hole is still a little "8" shaped and I can't see this being a sound joint.
Should I
1. Build on
2. Put in another rivet in between this screw up and the adjacent hole? Of course, this would put it right near where I fluted the rib.
I'm also concerned because the edge of the hole is a little gnarled and I'm thinking its a good place for a crack. I tried to dress it up but that also makes the hole bigger.
It's on the bottom of the stab so cosmetics don't concern me too much here.
Suppose I should use the power tools for setting rivets, not dimpling, huh?
Thanks for advice.
John B
Mooney M20C (KPSK)
RV7 Wings
www.pdfplates.com
Old 05-30-2007, 04:27 PM
dan's Avatar
dan dan is offline
Build on. Inboard rib flanges...if it's on the top, it gets hidden under the emp fairing. If it's on the bottom, well, it's on the bottom! Since yours is on the bottom...phew...no sweat.
Remind me to point out my "extra hole" on the bottom of my HS skin next time you're flying in very close trail...
Dan Checkoway RV-7
Old 05-30-2007, 04:34 PM
unqualified unfluencer
Welcome to the extra hole club. Build on. I'll show you my 'dimple 8' someday.
800hrs on Flash and still flying somehow <g>.
b,
d
Doug Reeves (your host)
Old 05-30-2007, 04:39 PM
Ha. Thanks for the quick replies. I guess this is one of those things 'real builders' do. Still haven't drilled my finger yet, but it's a long road ahead!
Building on...
John B
Mooney M20C (KPSK)
RV7 Wings
www.pdfplates.com
Old 05-30-2007, 04:48 PM
Mel's Avatar
Mel Mel is offline
My first "drilled finger" was on my 3rd airplane in 1984. Actually it was a team effort. I was holding the back of the longeron on my Moni Motorglider and my building partner was drilling every other hole. He forgot to skip a hole and found my thumb.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-30-2007, 05:05 PM
mburch's Avatar
mburch mburch is offline
You're lucky, my dimple-eight is on the top of my HS! Now I always use the hand squeezer to make dimples...
Keep on building, and if you're like me you will move on to bigger and more impressive mistakes. Did I say mistakes? I meant "things"...
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 05-30-2007, 07:26 PM
rmartingt's Avatar
My drilled finger happened when the bit went right through an existing hole in the wood block I was backing the hole up with, and into the side of my thumb. OUCH.
As compensation, my dad took me up to the training center to fly an MD-90 sim the next day.
Old 05-30-2007, 10:11 PM
rickmellor rickmellor is offline
LOL! I drilled my finger on my first day of emp work! I was like "gee, I always wondered how someone could do such a thing!".
Btw, keep on using the pneumatic for dimpling... it's a life saver. After this you'll slow down with the squeezer and will move on to all the other types of mistakes.
-Rick
RV7A (aborted in 2007 )
Brooklyn, NY
Old 05-31-2007, 02:59 PM
apatti apatti is offline
My extra hole is in the HS also. However, it is not really a "dimple-8". I messed up so bad that the extra hole was a long way from the target. I was able to just set a rivet in it and move on.
I don't usually use the pneumatic dimpler on skins since you usually have to drag out the C frame anyway. But, I sure do love it for ribs and other non-skin parts.
I have lost count on the number of drilled digits. I dropped the drill the other day and ended up with a #40 hole in my ankle. Since I couldn't buck a rivet there I had to drill it out to #30 and use a CherryMax! Ouch!
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
Old 05-31-2007, 10:37 PM
Bill Dicus Bill Dicus is offline
Default Dimple 8
I did the extra hole and dimple in an elevator skin = stupid, huh - well, it was late at night... Called Van's to order new skin and they said just flatten out, fill hole with JB Weld and carry on. I pounded too hard on the skin to flatten and stretched it. This can't be fixed and I needed a new skin. So be gentle flattening the dimple if you can. Bill
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
