Old 04-27-2020, 06:38 PM
greghughespdx's Avatar
Default Lycoming engines - limited time opportunity for quick delivery
https://www.vansaircraft.com/2020/04...ental-engines/
This almost never happens, and wanted to make sure everyone had a chance to be aware...
Lycoming has opened up limited capacity to build some fast-delivery experimental engines for delivery in the June/July timeframe. This opportunity is for standard experimental engines only – Thunderbolt engines are not available on this special schedule. Please reach out to Chris at Lycoming – his contact info available at the link – to see if the engine you need can be scheduled. Note that the specific engine you need and parts availability etc. will determine whether you can grab one of their fast-delivery slots. Once you have arranged things with Chris, you can place your engine or engine+prop order with Van’s and get things moving. Availability of slots is limited, so don’t delay.
Greg Hughes - Van's Aircraft
Building RV-8A since Sept 2014
Aurora, OR (EAA Chapter 105)
Old 04-30-2020, 05:05 AM
buchaneer buchaneer is offline
Yes I had an email from Chris saying he may be able to supply earlier due to cancellations which initially I was over the moon about but that soon evaporated.
Unfortunately as I live in UK and I had engine + prop+ loads of other bits it would involve dual shipping costs at vast expense so had to decline the offer.
Duncan Kenworthy
QB RV-9A Tip-up (has become slowbuild !!)
Tail feathers and wings done apart from glasswork! Working on the rest!
Reg number reserved: G-RVSK
Donation made for 2020
