Old 04-27-2020, 03:28 PM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
Default Flexible ADSB/Transponder antenna
My ADSB and Transponder both use the little TED antenna below. For some reason I like breaking these things when I'm under the plane. I'm up to two now. Is there a flexible version of this thing??
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019, 2020, 2021 donor and happy to do it.
Old 04-27-2020, 03:51 PM
PhatRV PhatRV is offline
I haven't flown but I bought a low profile blade antenna for my RV8. I also thought the single pole model is too easy to break.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Done. Fiberglass 80%
Avionics Installation -- 90%
Firewall Forward -- Cowl completed. Baffle 90%
Electrical -- 90%
Donation paid through 2021
Old 04-27-2020, 04:15 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Blade
I also use a blade from Delta Pop Aviation, and thus just listed my monopole like yours for sale.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 04-27-2020, 04:29 PM
lr172 lr172 is offline
I have broken a few. I solder them back on with silver solder and keep them in the plane as spares. They are not hard to disassemble for soldering. Just need a jig to hold the rod in place.
Larry
Old 04-27-2020, 05:59 PM
jliltd's Avatar
jliltd jliltd is offline
On an aircraft that flies as fast as and RV the blade shaped antennas have a lot less drag than the ball and stick type. You wouldn't guess it by looking but the round profile (cylinder) has significantly more drag. Google it.
So why not upgrade to a blade type?
I have a few TED brand antennas and on my Aviat Husky the white nylon support keeps falling down the stem rather than staying in place. This might be another one of those you gets what you pays for situations. I still have about 10 each of the TED UAT and TXP antennas new in the baggie. I use them for slower airplanes. But understand the difference between a $25 antenna and a $100 antenna.
Jim
Jim Ivey
RV-8
(and a few more airplanes)
Old 04-27-2020, 08:39 PM
ReidVaitor ReidVaitor is offline
Default Ted antenna
I built a fiberglass shark fin and put the antenna inside it, looks like the expensive ones but it costs about $6 to build one
Create foam mold big enough to fit the antenna into, when you have the right size (Remove the antenna) cover it with micro balloon mixed with resin and lay a couple ply of fiberglass over it, sand it, get 3m double sided (15lb) tape and install over the antenna on plane.
Been working for years without an issue. Did it for both the ADSB and transponder antenna.
Old 04-27-2020, 08:47 PM
Scott Hersha Scott Hersha is offline
True.... But ?a lot less drag = about 1/4 KTAS on an antenna of this length. I?ve broken 2 of these antennas, one Delta Pop blade, and one of the rod/ball antennas.
I re-epoxied the DP antenna, and then just straightened the rod/ball unit. Both check out fine on the bench. The rod unit has been flying , after bending it back to straight, for 3 months, including a transponder recert/ADSB test, and it?s working fine so far. I?m sure my DP antenna would too.
Dirty air on your belly doesn?t pay the same penalty as something in smooth air. A rod antenna is definitely more ?draggy? than a blade, but is it worth 4X the cost? Especially if you think you may damage it cleaning the belly, maybe more than once? I still have my repaired DP blade if anyone wants to buy it. I?ll sell it to you for the cost of a six pack - your choice on brand.
If you are anal about cleaning your belly (99% of us are), you WILL damage a belly mount antenna eventually. You will need to repair or replace it.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
Old 04-28-2020, 09:07 AM
Snowflake's Avatar
I sense another part coming from Steve from his 3D printed parts factory... A shark-fin to fit over the stub antenna would be pretty easy to print.
Rob Prior
Old 04-28-2020, 07:30 PM
I?m in if he does it. He?s a hangar neighbor, so I will be happy to Beta test it!
SH
Cincinnati, OH/KHAO
JAN2021
Old 04-29-2020, 02:59 AM
jliltd's Avatar
That would be great if he did. I would encourage him to use the UAT tuned version vs the transponder tuned version. The UAT is ever so slightly longer due to the lower 978 frequency and it takes a keen side by side comparison to notice the difference. But it does exist. The 978 Mhz UAT length cover would be backwards compatible with the 1030 Mhz/1090 Mhz version.
Jim
Jim Ivey
RV-8
