  #11
Old 04-28-2020, 08:54 AM
Av8torTom's Avatar
OK, so sounds like a progressive switch that is off, Nav on, Nav and Strobes on would work. Then maybe a separate switch for wig-wag and one for landing lights? So a total of 3 switches. Thoughts?
N677AT reserved
Superior XP O-320, 160HP
Old 05-23-2020, 12:15 PM
Steve Crewdog Steve Crewdog is offline
Hi Tom,
Human Factors are something I love studying, so when it came time for my switchology I wanted to make it as simple as possible. If the switch is Down, the system is OFF. If it's Up, the system is ON. All my switches are grouped by system or phase of flight, if I have to turn everything off because of an electrical problem it's one swipe of my hand down without looking or thinking.
I'm using the AeroLED SunRay Plus LED landing light that has it's own built-in wig-wag, so I've got a 3 way switch from Mouser that is OFF-ON-ON, it will be wired Off-Steady (for night flying)-WigWag (for normal daytime ops.) I use the same switch for my heater and it's OFF-LOW-HIGH.
I go more into the design of my panel here: https://seareybuild.blogspot.com/201...with-flow.html
Take care,
Steve
SeaRey builder lurking to get ideas to make his plane better.
Dues paid for 2020
http://seareybuild.blogspot.com/
Old 05-23-2020, 12:37 PM
+1 for keeping it simple.
Tom, with an ?off-nav-nav+strobe? switch, imagine landing at night with that switch full on. Turning off the runway, you see other aircraft, so you want to turn the strobes off. But it?s too easy to move that switch to full down without noticing, and now you?re taxiing in the dark with no nav lights.
Old 05-23-2020, 12:41 PM
Tom, with an ‘off-nav-nav+strobe’ switch, imagine landing at night with that switch full on. Turning off the runway, you see other aircraft, so you want to turn the strobes off. But it’s too easy to move that switch to full down without noticing, and now you’re taxiing in the dark with no nav lights.
+1, Bob, a few years ago we had a AOPA seminar on night flying, afterward we all stood outside and watched an attendee taxi out with their nav lights Off, but with beacon and taxi light On. Them who have, and them that are going to, I might have done that myself, too. Maybe even more than once.
Dues paid for 2020
