Old 04-21-2020, 10:13 AM
Reilly Reilly is offline
Default Opinion on my canopy fairing please
Hi guys
My first fiberglass effort and not unhappy with it so far.
I would just like some opinions from the gurus on the area and gaps around the hinge bolt holes. I know its a less attractive part of the 12 but are mine too large or is this how it should be? I did take time to ensure that the bolt hole on the template was directly over the bolt.
Appreciate the feedback
Old 04-21-2020, 10:33 AM
NinerBikes NinerBikes is offline
What are we supposed to be looking at? No picture is appearing.
Old 04-21-2020, 10:52 AM
Sorry did not know that the way to post pics had changed. Hope you can see them
Old 04-21-2020, 11:08 AM
https://www.dropbox.com/s/67zrwwjxx4...63745.jpg?dl=0
Old 04-21-2020, 11:11 AM
https://www.dropbox.com/s/zf553xtrje...63807.jpg?dl=0
https://www.dropbox.com/s/m3tgu3hhm6...65027.jpg?dl=0
Hope they visible now
Old 04-21-2020, 11:24 AM
DHeal DHeal is offline
Find a socket that fits the pivot bolt head. Wrap a couple of turns of electrical tape around the outer circumference of the socket. Put the socket on the bolt head and fill the outer gaps with fiberglass resin. Remove the socket and clean up the hole. After final painting you can cover the hole with a circular piece of tape or a snap-in grommet.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,080+ hours (as of Oct 2021)!
VAF donation through June 2022.
Old 04-21-2020, 11:47 AM
Thanks David that is my plan for the holes.
I am just not sure of the gaps forward and above of the bolt hole between the fiberglass and the top skin
Old 04-21-2020, 12:47 PM
Just trim those edges so that they don't rub on the aluminum panels when the canopy is opened and closed. Be sure to leave sufficient room for final paint thickness on both parts (fiberglass and aluminum). Also, be sure to trim the upper forward side portion of the canopy fairing so that you can access all of the screws in the avionics bay cover -- follow the plans. In some cases, cutting the clearances too closely may come back to haunt you as the airframe ages and is used.
Old 04-21-2020, 01:57 PM
Janekom's Avatar
Janekom Janekom is offline
Looking good Reilly
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2021 WITH A SMILE
Old 04-21-2020, 04:45 PM
wirejock's Avatar
wirejock wirejock is offline
Default Fiberglass
Love the socket trick. Gotta remember that. Looks good. Not sure I would ness with the gap.
However, if you really want...
The gap can be fixed a couple ways. One is heat. Warm it with a heat gun or blow dryer till almost too hot to hold a hand on it. Any hotter and it bubbles and it's toast. Weight it down till it cools.
The other is to apply a release like packing tape to the fuse. Apply a bead of floxed epoxy. Close it so the flox mix squeezes into a seal. Leave it till it cures. Should fit perfect.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
