Old 04-20-2020, 01:20 PM
dwranda dwranda is offline
Default Is this the right cover for removal of c/s governor?
Removed my governor pad since I am using a fixed pitch prop. Is this the correct cover for my situation? Thought I read somewhere about the cover needing areas on the back for oil to be routed. As you can see the cover I got from Vans is just solid with no recesses on the back.
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid April 2021
Old 04-20-2020, 04:08 PM
Isaac's Avatar
Isaac Isaac is offline
Default Re: Convert CS to FP
http://www.vansairforce.com/communit...rt+fixed+pitch
___________
James D.
RV6 N947J
Old 04-20-2020, 04:25 PM
Thanks. So it looks like if i took the governor pad and steel line to the front off then I'm good with the cover i have. If i kept those on the plane i would need the cover plate with the recessed back that would cover the back of the governor pad.
9A in progress
Old 04-20-2020, 04:26 PM
BobTurner BobTurner is online now
Carefully read the reference in the last post. If you remove the piece in your top photo, then you have the right cover, but you must also do additional work inside the crankshaft. If you reinstall the piece in your top photo (the gear that goes inside the crankcase) then you need the cover with the channel in it, but do not have to change anything inside the crankshaft. Your choice.
Old 04-20-2020, 06:49 PM
griffg griffg is offline
Default Conversion to Fixed pitch
Have you read the Lycoming Service Instruction No: 1435 which gives instructions on converting both ways.
Gordon Griffin
RV-7A under construction
VH-NAK
IO-360-M1B
Catto 3 blade prop
Old 04-20-2020, 07:54 PM
Yes I've read the service bulletin but it only says to use the proper cover for the accessory pad on the back. Yes i also am aware about either removing or piercing the plug in the shaft up front. Since i removed the governor pad i will use the cover i have and have an A&P help me with the plugs up front when i move it to an airport. That way hopefully the front plug will be installed correctly since I've never done that before. Taking this stuff off the engine saved almost 2.5 lbs that would have been dead weight. Thanks everyone for the input!!
9A in progress
