04-22-2020, 07:20 PM
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
04-23-2020, 12:25 AM
RV3 LEMO Plug
Here is what I did in my RV-3B. If you look at the bottom portion of the diagram it shows how to hook the LEMO wires to legacy headset jacks. This makes it really easy to add LEMO.
RV-8
(a few more airplanes too)
04-23-2020, 08:49 AM
Originally Posted by Bob Y
To reduce the potential for induced noise, I would highly recommend taking the negative of the power circuit - black LEMO lead - to the airframe ground vs. through the audio panel. It might work ok, but why introduce the potential risk?
As a rule of thumb I might agree. In fact I take it one step further than you and make sure any system device such as this gets its power ground from the common avionics ground point. But in this case I followed instructions. Bose specifically specifies these exact wire connections in its documentation and on on its drawing. I speculate that Bose realized if they showed the black wire going to ground the installer might decide to ground locally rather than the avionics ground point, which could induce ground loop interference. So while I stick to generally accepted practices like the avionics ground point when no guidance is given, when a manufacturer like Bose says to do it a certain way who am I to argue? And my installation works great.
Jim
RV-8
04-23-2020, 11:45 AM
I completed wiring both LEMO plugs last night. Here is what I found: - IF you want the connector to be flush with the seatpan/ramp, then installing it per KAI (1 inch aft of the exist jacks) won't work. The LEMO pigtails interfere with a stiffener. I question whether or not someone would want this plug to sit flush though.. I picture breadcrumbs getting into this connector over time. If you allow the connector to protrude at the maximum amount possible (about 1/4"-3/8"), then you may have a chance to get the pigtails to not be squished up against the stiffener.. but it seems safer to just install it 1" forward of the existing connectors ( as measured from the center of the mic hole).
- The LEMO pigtail was slightly confusing. Normally, I'd peel back the audio cable braids a bit and put a solder sleeve on it and "convert" the braid to a wire. That has already been done for you -- the headphone braid is a black wire w/ white stripe .. and surprise, the mic braid is also a black wire w/ white stripe. Which is which is an exercise for you and your multi-meter.
- There IS a red pigtail for power, AND a black for its return (in my previous post I didn't notice it, sorry). Where to ground it? probably the pilot-controls/wingroot point. I'm sure the headset has a DC-DC converter and some noise filtering caps in it.. and the audio/mic line grounds are grounded at the radio/audio panel only.. So I don't think there will be any noise issues. Though the true test is always in the air.
Overall, if I could do it over again, I would have just called Stein, thew them some extra money and had them wire in the jacks (I solder electronics all the time, but adding on wires to terminals after the fact is always a pain compared to doing everything up fron). I don't want to say it should be a STANDARD feature to the -12 because it adds about $100..but could be offered as a factory/Stein option.
Rob Carsey, North Brunswick NJ
RV-12iS (N713)
Tail 100% done
Wings 95% done (AOA)
Fuse 100% done
Finish 100% done (cowl)
Avionics 100% done
Dues paid 2019
04-24-2020, 05:39 AM
Originally Posted by rcarsey
Overall, if I could do it over again, I would have just called Stein, thew them some extra money and had them wire in the jacks...
This is in the finish kit, not the avionics correct? I just ordered my finish kit, wondering if I should try the suggestion to have Stein do it...
Bobby Steinmetz
Van Buren TWP, MI
Student Pilot, Mechanical Engineer
RV-12is Empennage Kit, Fuse Kit, #121228
N781PT Reserved
Donated 2020
05-31-2020, 10:40 PM
Yes, I'm sure Stein would add the plugs for you for a nominal charge. But, if you do it yourself, I recommend doing it before putting the harness in the plane.
I should mention now that after my initial wiring of the plugs in April, I finally got around to testing it with a headset. I found that I had no audio in my right-ear.
After much head scratching, it turns out that the LEMO diagram in the latest RV-12 electrical diagram was incorrect. After consulting with the mothership, it appears that someone cut-pasted the RV-14 diagram into the RV-12 schematics. While the wiring is essentially the same, the RV-14 uses a different wire color for headset-ground and headset-right. (white/orange and white/blue are swapped).
During testing, I noticed that even with new legacy jacks, I got the typical crackling/scratchyness when rotating or jostling the headset's connectors.. which I sorta expected.. I've experienced that in almost every plane I've been in. The LEMO plug on the otherhand.. the audio was rock solid even when applying abnormal forces to the connector.
RV-12iS (N713)
Tail 100% done
Fuse 100% done
Avionics 100% done
Dues paid 2019
06-02-2020, 08:24 AM
No Joy
Response from Stein in regards to adding LEMO plugs to an RV-12iS wiring harness:
Hi Bob,
Unfortunately we have a firm "no customizations" for all the RV-12iS kits here.... Your welcome to purchase the jacks and add them in yourself though if you'd like? They are $75.95 per place, and require an additional power wire.
Thanks!
Nicholas Millard
Operations Director
Stein Air, INC
Bobby Steinmetz
Van Buren TWP, MI
N781PT Reserved
Donated 2020
06-02-2020, 10:44 AM
The black wire coming from the Bose LEMO is the power ground. It needs to be tied to the airframe ground to complete the power circuit.
The ground wire on a lemo connector feeds both the power ground AND the headset speaker ground. I believe it is recommended that this ground wire connect to the intercom ground buss or headset ground pin, depending upon intercom type. Connecting the lemo ground pin to an airframe ground introduces the risk of a ground loop on arguably the device most sensitive to ground loops, the headset speakers..
Larry
06-02-2020, 11:43 AM
Wow, that's a lot of money. $75 will buy 2A Alkaline batts for my Zulu3's into the next century...
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
06-02-2020, 11:52 AM
Larry
Larry. Good catch. You are correct.
That is depicted 8 posts up in the drawing. The LEMO ground is attached to the headphone ground circuit per Bose's instructions.
RV-8
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
