Old 05-29-2007, 12:37 PM
Jim P's Avatar
Jim P Jim P is offline
Default Plane-Power EI60 Install
I received my IO-360-M1 with the Plane Power EI60/B alternator installed. The down side was that I was expecting a B&C externally regulated and have already wired with the LR-30. It looks fairly straight forward to remove the LR-3 and wire in the new IR alternator.
Anyone done this yet?
Jim
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 05-29-2007, 02:02 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Easy
Jim
You are right it is straight forward, there is nothing to it. Remove the LR-3 or 30 or whatever and sell it for +$200 or return it to B&C for credit and put that in your gas fund.
Don't be disappointed, you have saved money and weight and if you would have gone with the Plane Power set-up to start, saved wiring and installation time.
The big wire B'lead or output is the the same.
- Forget the field wire, gone
- "Alt Field" connect to terminal #1 & #2 (I think) on plane power
- "Lamp" connected as Plane power shows #3, 1 amp.
Just follow plane power's instructions.
Done deal, there are no gotcha's, just remove the external regulator and collect the cash.
The money you get for the regulator will pay for 1/2 the alternator and internal regulator with all the mount hardware. I would be happy.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
