Trim warning light on G3X and g5 all the time
Hi
I have Ray Allen trim servos powered from gsa28s,...the trimworks in the correct sense and the autopilot (507) moves in the right direction.
The trim works correctly with the AP on or off. The red Trim annunciation is on all the time on both the gdu46 and g5 screen... help! What?s wrong?
TRIM Annunciation
Hi
Good Morning,
Walt is correct here. Power on the display in configuration mode, touch LRU and disable any trim servos you have enabled. These settings are used to enable a GSA 28 servo as a trim motor.
Justin
