Old 05-27-2007, 07:02 PM
tx_jayhawk tx_jayhawk is offline
Default Cleaning Wingtip Lense?
I have used Naphtha to clean the canopy, and it seems to work great. Should the same be used to clean the wingtip lense? It seems to be a different material, and I wanted to make sure the same cleaning "rules" apply.
Scott
7A Finishing
Old 05-27-2007, 07:34 PM
Mel's Avatar
Mel Mel is offline
Not sure what the wing tip lenses are made of, but if they are Lexan, be careful. Polycarbonate (Lexan) does not do well with many chemicals, including gasoline and acetone.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-27-2007, 07:42 PM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
Default water?
I've always just used a soft cloth and water...
RV7A-QB, RV-10
Old 05-27-2007, 08:51 PM
John Clark's Avatar
John Clark John Clark is offline
Default Soap and water
Mild soap and water for normal cleaning, some Plexus or Maguires #17 if it needs a little more polish. If the lenses are polycarbonate (Lexan) NEVER use a polish containing silicone. For the plexiglass (acrylic) canopy the same advice, soap and water, Plexus, Maguiers but avoid anything with ammonia (Windex.) The ammonia will, with time, cause the surface to "craze."
John Clark
RV8 N18U "Sunshine"
KSBA
Old 05-28-2007, 08:55 AM
Soap and water I'm sure is fine, but there is some adhesive that needs something stronger.
I was hoping to find a solvent of some type that others have used successfully.
THanks,
Scott
Old 05-28-2007, 09:49 AM
treeez treeez is offline
When I was on the police force in S Tx, I used FLITZ cream on my over head lights that were severly oxidized. Worked great to clear them up. It is a very, very mild polishing compound, even used it on blued guns with no damage to the finish. With a little elbow grease it would probably take the adhesive marks off. Might try it on a very small spot on the underside of the lens just to be safe.
Mike
Old 05-28-2007, 11:38 AM
JimWoo50 JimWoo50 is offline
Default lemon pledge
I use it on my 172 windshield and it shines it up real nice and it takes the bugs off too. Used it on my rv windshield and same result.
Old 05-28-2007, 09:41 PM
WildThing's Avatar
WildThing WildThing is offline
THanks,
Scott
If the adhesive is from tape, stickers, etc - try WD-40... it works great for the gooy stuff and shouldn't hurt anything on a plane.
Jeff
Old 05-29-2007, 09:32 AM
mtclay mtclay is offline
Certainly no guarantees, but on the car repair TV show "Two Guys Garage" I saw an interesting technique.
They were spiffing up an older used car for one of their buddies. On the cloudy and nearly opaque plastic headlight lenses they used plain old TOOTHPASTE on a rag. It made a tremendous improvement!!!
Mike Clay
Orlando, FL
RV-8A N81PD
Old 05-29-2007, 11:03 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Try "Goo Gone" for the adhesive residue.
Mike
