Go Back   VAF Forums > Model Specific > RV-14
Old 03-31-2020, 03:42 PM
Gregmarlow's Avatar
Gregmarlow Gregmarlow is offline
Default Vent block off FF-0084 and vetterman exhaust
With the vetterman exhaust, is the vent block off plate on the right side necessary? With one heat muff, I see that it probably should be, but does the vetterman come with 2 heat muffs, each feeding it's own side?
Greg Marlow
RV-9A Flying - sold
4 pl Bearhawk - flying ("sold" to the insurance company)
RV-14A - flying
Dues gladly paid
East Tennessee/SW Virginia
Old 03-31-2020, 04:16 PM
JTJones's Avatar
JTJones JTJones is offline
Default Yes it does
Yes, two heat muffs. I added a second flange on the back left baffle with a second scat tube so each heat vent has its own source.
This shows the flange...
I considered that sourcing air from the aft baffle could introduce ?bad air? into the cabin but I haven?t noticed a difference between the right heat vent and the left except it may be a bit hotter.
I also didn?t use the stock heat valves but used stainless valves.
Jeffrey T Jones
RV-14 N588TJ Completed
First Flight July 10, 2018
Flight testing completed August 14, 2018
2021 VAF dues paid plus beer money😜
Old 03-31-2020, 04:31 PM
Gregmarlow's Avatar
Default Flange
Great. Where did you source that flange?
Greg Marlow
RV-9A Flying - sold
RV-14A - flying
Dues gladly paid
Old 03-31-2020, 07:20 PM
JTJones's Avatar
Default Flange Source
I sourced the flange from Aircraft Spruce:
ALUMINUM FLANGE 2" 10350-8
Jeffrey T Jones
Old 03-31-2020, 08:00 PM
Gregmarlow's Avatar
Thank you sir!
Greg Marlow
RV-9A Flying - sold
RV-14A - flying
Dues gladly paid
Old 04-01-2020, 05:43 AM
Jetmart's Avatar
Jetmart Jetmart is offline
Hi Jeff,
Where did you get the stainless heat valves? Are they completely stainless including the valve flapper? My MDR is requiring the flap to be stainless.
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
RV-14 Kit # 140694
First Flight - June 22, 2021
2021 Dues Paid
Old 04-01-2020, 12:46 PM
JTJones's Avatar
Default Also Spruce
I sourced the valves from plane innovations but I think they went away, I can?t find them on the internet anymore. Spruce has them though. Search:
HEATER BYPASS VALVE WITH CABIN SIDE CONTROL LEVER FOR RV-7, RV-8 AND RV-9
They will work on the -14.
Jeffrey T Jones
JTJones's Avatar
Default Sorry
Yes, flapper is stainless...
Jeffrey T Jones
Old 04-01-2020, 02:37 PM
Jetmart's Avatar
Thanks Jeff
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
RV-14 Kit # 140694
2021 Dues Paid
