Old 03-29-2020, 11:56 PM
wjb's Avatar
wjb wjb is offline
Default Is your Andair pump noisy?
Does your Andair fuel pump make a racket?
I was happily surprised by how quiet the pump was when I was doing fuel flow tests last weekend with no back pressure ... purred along with a nice low hum.
However, once things are tight and pressure comes up, it makes a nasty racket. Almost like screeching sound ... it's very obvious in my first engine start video; pump is turned on on at 0:14.
https://www.youtube.com/watch?v=T6wuyqh9ejE
Is this typical, or is my pump unhappy? It's making 30+ psi in this state, so it's not slouching there.
Bill Bencze
N430WB RV-7 @KHAF, Flying 100+ hrs
VAF 2021 donation happily made
Old 03-30-2020, 01:57 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default same as mine
Mine sounded about the same from what I could hear on the video. It does make some noise. No idea if it's normal or not, but like yours, it's moving some fuel and making pressure.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 03-30-2020, 03:04 AM
Peter Costick Peter Costick is offline
Mine works fine, nothing to mention as far as noise is concerned. I mean, I can hear it but it doesn't worry me.
Peter Costick
Melbourne Australia
RV7A Flying, VH-SVN
2020 Donation Made
Old 03-30-2020, 06:11 AM
SuperCubDriver SuperCubDriver is offline
I once had a pump which made this noise. It failed a while thereafter.
RV-7 flying, IO-375 w. P-Mags, 200RV Prop
RV-8 flying, IO-375, P-Mags, 74RV Prop
Old 03-30-2020, 07:16 AM
pilotkms's Avatar
pilotkms pilotkms is offline
Default +1
I bought an Andair pump originally and the noise was similar. No ?ON? indicator needed. Sent it back. Bought an EFII pump. Super quiet and super happy.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying K
Built in SoCal KCCB, now in GA @ KPXE
800+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019 & 2021
Old 03-30-2020, 07:58 AM
PhatRV PhatRV is offline
Slightly off topic, how noisy or quiet is the Air Flow Performance fuel pump from Vans?
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Done. Fiberglass 80%
Avionics Installation -- 90%
Firewall Forward -- Cowl completed. Baffle 90%
Electrical -- 90%
Donation paid through 2022
Old 03-30-2020, 08:11 AM
MarkW's Avatar
MarkW MarkW is offline
I could not hear your pump in the video.
My Andair has done well for 6.5 years and when things are normal it doesn't make much noise. I have had a couple of times where it lost prime and it make s very different noise. After a few minutes of no prime it will screech. I try not to run it long like that as it sounds bad. Get it primed and it is quite again.
With head set on and engine running I can not hear it.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 03-30-2020, 09:35 AM
9GT's Avatar
9GT 9GT is offline
The Andair pump I put in my RV-10 was quiet. You could hear it run, but it did not make any alarming noise. I went with the Andair pump because I thought that the AFP pump we put in the Cozy was excessively noisy! The Andair was a little quieter than the AFP pump. I may try the EFII pump on the RV-9A.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 03-30-2020, 10:18 AM
Tankerpilot75's Avatar
Tankerpilot75 Tankerpilot75 is offline
My hearing sucks (retired military pilot) but in answer to your question - not noisy!
I hear it when I turn the pump on to prime just before engine start.
I do not hear it in flight if I turn it on, which has contributed to me forgetting to turn it off a few times. On my aircraft that can result in higher fuel flow indications because excess fuel is pumped out the fuel pressure relief line. I do have a small warning light on my panel that illuminates when it?s turned on but I have often failed to see it. Just being old!
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360, Hartzel CS prop, Dual GRT Horizon EX with ARINC, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level & auto-trim, Tosten 6 button Military Grips, FlightBox wired to EX, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, New TS Flightline hoses, Great POH!
Retired - Living the dream - going broke!
Old 03-31-2020, 06:42 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default Very quiet
The Airflow unit is dead quiet.
Best,
Mark
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
