  #11
Old 03-29-2020, 09:28 AM
rsr3 rsr3 is offline
Ok everyone, thanks for that. So, fit them such that they can be removed as required, fair enough. Sounds sensible.
Using screws and tinnerman washers sounds like the easiest way, but I do like the idea of minimal visibility that the hinge method offers. If I went down the hinge route, how do you stop the hinge from pulling the rivets through the fibreglass on the wingtip half of the hinge? That must be quite difficult to reinforce, unlike the screw method by which a strip of aluminium can be riveted inbetween the nutplates and the fibreglass of the wingtip.
Thanks!
Old 03-29-2020, 09:35 AM
climberrn's Avatar
climberrn climberrn is offline
An adhesive under the aluminum strip or hinge would reinforce it well. Also, instead of tinnermans, consider thin SS flat washers, pressed in the appropriate dimple die. Smaller, clean and effective.
Joel
N626JA
RV-7A at CXP
Flying!
Old 03-29-2020, 09:36 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default floating nutplates
Originally Posted by PhatRV View Post
I just found out about the floating nutplates. Sometimes the handmade holes don't quite aligned and the floating nutplates saved the day.
Indeed, they are really nice. I bought a big bag full at Oshkosh from one of the tent dealers there - it was no where near as expensive as the normal price.
The nice thing is that the screws line up perfectly with the dimpled hole, no sideways stresses.
The torx screws make it fast and easy to install and remove with an electric screwdriver without worrying about stripping the head.
Be careful riveting the floating nutplate on - if you are not lined up right with the rivet you can pinch the nutplate and it won't move freely.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 03-29-2020, 09:45 AM
Discus2b Discus2b is offline
I built my RV simple. Used pulled rivets per plans. I have position lights only in my wingtips and bulbs/connectors are easily inspectable. However, through 9 years of flying I had to remove the tips twice. Once I hit a hard snow bank while taxiing and second time buchered both leading edges on rollout. I would install screws or combination screws/hinges if I do it again. It would make repairs easier
Always learning from others....snow bank..check, do not hit. Got it.
Rollout...do not butcher leading edges....?? Overrun into corn field maybe?? Flock of boids....??
R
Old 03-29-2020, 10:54 AM
9GT's Avatar
9GT 9GT is offline
I prep both surfaces and then Fay Seal all my hinges and backing aluminum for fiberglass parts with Pro-Seal, then rivet after they Pro-Seal is set.
David C.
Howell, MI
Old 03-29-2020, 07:30 PM
Blain's Avatar
Blain Blain is offline
If it?s a taildragger consider making it removable. Ground loops are hard on wingtips.......
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2020(my reminder)
Old 03-29-2020, 08:06 PM
bruceh's Avatar
bruceh bruceh is offline
Probably depends on what you put in the wing tips. I have my APRS antenna and unit in there. I had to replace the antenna a few years ago when it stopped sending out packets. Found a loose wire. I know others with Archer COM/NAV antennas in the wing tips. Most likely you will want to inspect in there at some point down the road, or add/change something.
Bruce Hill
2020 VAF donator
Old 03-29-2020, 08:08 PM
Northernliving Northernliving is offline
Originally Posted by rsr3 View Post
I've got to that stage of the build where I'm giving thought to attaching the wing tips. I've seen different methods of attaching them, such as:
- pulled rivets
- screws
- hinges
I think I'm unlikely to remove them once they're on - even with annual inspections I can't see that there will be a great deal to be gained from taking them off, when a borescope could do the same thing?
If anybody would be good enough to explain their reasoning for their chosen method of attaching the wing tips that would be very useful.
Thanks in advance!
Rob
- hinge would be my vote. Easy, no paint damage removal. Never say never. You will end up back in there for some reason.
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 03-29-2020, 11:01 PM
N546RV's Avatar
N546RV N546RV is offline
Plus the hinge setup looks super slick! (at least to my eyes)
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 03-30-2020, 10:29 AM
Ok - hinge set up it is, then. That was my initial thought but as time went by I thought that just blind riveting them on would be quick and easy.. i.e. Lazy!
Final thought - I think - would you recommend using AD4 rivets to put the hinge on so that the rivet head is a bit bigger and more reluctant to pull through the fibreglass?
Thanks for taking the time to reply everyone, it is really appreciated.
Rob
