Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
  #11
Old 03-28-2020, 04:21 PM
Jpm757 Jpm757 is offline
I downloaded the new software to my data card and installed it on my GNC355. When finished, I could not get the unit to power up in normal mode, it would stay in the configuration mode. Once I removed the data card the unit powered up normally. Apparently if you leave the data card in your unit without deleting the software update it wants to reinstall the update every time it is powered on. Up to this point I have always left my data card in the unit for safekeeping, however I would recommend either downloading the update on a separate data card or deleting the software update from the nav data card.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 03-28-2020, 09:10 PM
rvmills's Avatar
rvmills rvmills is offline
Jake,
Concur with your findings. Another VAF bubba at RTS downloaded the software update on a separate card, and we both used that card. While I was loading the software update in my 375, I downloaded a Nav Database update on the Garmin card, and when the software update was complete, shut down, swapped the cards, and re-started. Worked like a champ! So good call Jake. (And thanks Brian for the help!).
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 03-30-2020, 07:29 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default Service Bulletin Document
This is covered in the software bulletin document, Part II Step 11 and 12. As part of the software update process, the software loader card must be removed from the unit once the update is complete.
Justin
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 03-30-2020, 03:29 PM
g3xpert's Avatar
Originally Posted by gblanck View Post
The service bulletin describes changes from v3.03 to v3.1. A unit we just updated hadn't been updated since it was installed and had v2.02. Are there change logs for releases between older versions available online anywhere?
-Greg
Update to 3.02:
  • Corrected incompatibility issue with KI 208A and KI 209A.
  • Corrected issue for GNX 375 with use of ?Generate ICAO from Tail? in config mode, so that use of this feature will now correctly calculate ICAO address.
  • Added display of GPS Boot software version in Config mode.
  • Changed default of user fields on the map to combined DTK/TRK (Desired Track / Track) in top
    right and DIS/BRG APT (Distance/Bearing from Destination Airport) in bottom right.
Update to 3.03:
  • Fixes an issue where some traffic targets may be missed when over 200 targets
    are in range
  • Fixes an issue where prioritization of selected traffic over
    non-selected traffic was not occurring. This could result in removal of selected traffic, if 60 or
    more other aircraft are closer than selected traffic
  • Clarified AFMS completion instructions.
  • Clarified installation instructions for aircraft without an avionics bus.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 03-30-2020, 03:39 PM
gblanck gblanck is offline
thanks for the changelog Justin.
Greg Blanck
RV-8 Completed March 2014
Redwood City, CA
RV-8 Build Log
Old 04-10-2020, 12:56 PM
Eagleflip Eagleflip is offline
Justin--
Thanks for the link to the web page for these updates. Will you post the newest G5 (Experimental) software update on the same page when it becomes available?
Sam
RV-6A (which I sadly admit I did not build)
Old 04-11-2020, 08:17 PM
FlyingBanker's Avatar
FlyingBanker FlyingBanker is offline
Default Transponder Fault
I did the update on my GNX 375 earlier this week and everything tested fine after the update.Flew today and I have a message on the G3X transponder display that says ?Transponder Fault?. No error messages on the 375. Checked in with ATC and they reported reading fine for transponder and ADS-B. Any thoughts on cause of alert and how to fix?
Jim Bedsole
N62MG - RV-6A "Promises" - bought flying
Dues Paid
Old 04-13-2020, 10:10 AM
g3xpert's Avatar
Default GNX 375 Error
Good Morning,
In configuration mode on the GDU, touch Transponder. There is a status box in the bottom left hand corner. What is displayed there?
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 04-13-2020, 01:57 PM
g3xpert's Avatar
Default G5 Software
Originally Posted by Eagleflip View Post
Justin--
Yes we will post any updates to the G5 software to the Experimental Software Download area as soon as they are ready, as well as post here to let everyone know it is available.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 04-14-2020, 01:24 PM
Originally Posted by g3xpert View Post
Good Morning,
Justin
It says "GNX 375 2.54 (Config Data Error)"
Jim Bedsole
Dues Paid
