Go Back   VAF Forums > Model Specific > RV-14
Old 03-23-2020, 01:11 PM
Mark Browning Mark Browning is offline
Default Problem with the elevator trim travel
Hi everyone
Just wondered if anyone could offer a solution as to why the elevator push rod doesn't seem long enough ?
I hooked up the servo to the elevator trim tab. With the trim set in the neural position and the servo on mid travel the push rod is too short ?
i have to run run the servo motor almost fully out so the clevis pin fits
Any help would be appreciated
Old 03-23-2020, 01:17 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Pics didn't post ...
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 03-23-2020, 01:28 PM
sorry now posted
Old 03-23-2020, 01:31 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Correct. Mid position on the trim servo does not translate to the trim tab in neutral. The set up is designed to provide much more nose up trim than down. But if memory serves there was replacement connecting link so check on that.
Carl
Old 03-23-2020, 01:32 PM
MED MED is offline
The trim tab travel is greater in one direction than the other. I?m pretty sure you will be fine.
MED
140236
N435MD
Miss March 2020
Old 03-23-2020, 01:43 PM
n982sx n982sx is offline
Looks about right but can't quite tell from your pic. The travel is supposed to be very asymmetric. Mid travel will not be close to neutral.
Not sure of your kit number, but if it's an early kit, be sure you have the updated arm.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 03-23-2020, 01:45 PM
Carl
Thanks Carl
Just noticed the tab travel limits are 13 degrees up and 35 Down so need to check that with the digital level
Old 03-23-2020, 01:50 PM
The kit is Feb 2016, do you know when the date range of the updated arm
Old 03-23-2020, 10:53 PM
My kit was from 2013. I discovered a problem with the arm travel in early 2014. When I called Vans they said "Ya, we're working on it.'' so I wasn't the first to spot it.
A new arm came in the mail shortly after. Way before 2016.
Bob Meyers
Old 03-24-2020, 10:26 AM
Hello Bob
Checking the min and max deflection on the trim i'm a little short in minimum up degrees... vans give "minimum up of 11, i have 8.5
I have checked the plans and the push rod length and piano hinge distances are correct.
I would be interested to see what measurements you guys have with max up defection when measuring with a ruler ? i have 11/16th
