Originally Posted by titanhank
My stinger was laser straight before bending. The 9deg bend was with a harbor freight pipe bender with the smallest die installed. I bent it cold. I used the tailwheel hanging weight on the end to ensure it was plumb. Overbent to 12 degs with spring back to the desired 9 degs. Worked like a champ.
Was the 12 ton pipe bender enough, or did you use the 16 ton?
