03-22-2020, 12:02 PM
pitot hardware help
Hey all-
Garmin Pitot tube calls for #6-32 fasteners about 1/4" long. Nylon patch recommended.
Does anybody know off the top of their head what a good part number and source might be for something like that with a 100 degree countersink and a nylon patch on the threads? Maybe with an Allen head?
If such a creature doesn't exist, my fall back plan will just be some AN507s with red lock tite, unless somebody tells me that's a bad idea on a heated pitot.
Terr
03-22-2020, 12:34 PM
Originally Posted by Desert Rat
Hey all-
Terr
I buy my hard to find parts like that locally at a store called ET Fasteners. There should be some kind of store like that in your neck of the woods with another name.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
03-22-2020, 03:13 PM
Hey all-
Terr
Don't think I'd use red Loctite...you may (will) have to remove it at some point in the future. Blue Loctite should suffice.
2019 Dues paid!
03-23-2020, 06:37 AM
Just done 2 Dynon pitot's on Gretz mounts and just shortened a#6 screw and used blue Loctite.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
03-23-2020, 08:06 AM
After a little more measuring and head scratching, I see that the wall thickness on the steel mast that I inherited with this project is about .050. The countersink on a AN507 (#6 machine screw) is about .090. In other words, it's a no go with a countersunk #6 unless I can find something with a smaller head i.e shallower countersink.
How are people dealing with this? Just using a pan head screw, shouldered countersink? or what?
03-23-2020, 08:48 AM
I've seen people using pop rivets to hold the pitot tube inside the housing mast. I am thinking of just using the pop-rivet dimpling tool on the mast and use the CS4 pop rivets. This is what I am planning to do in the next few months.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Started
Avionics Installation -- Bench tested
Firewall Forward -- New engine received !
Electrical -- After engine installation
Donation paid through 2020
03-23-2020, 08:50 AM
I just used round head screws, why do you need to countersink 4 screws? Drag speed loss of 0.0005 knots?
03-23-2020, 10:15 AM
Yup, pretty much- but I'm about to accept defeat and just use pan head #6 and try to find that .0005 kts somewhere else
03-23-2020, 10:34 AM
For me, I see a couple of potential problems with this.
On my setup, the back side of a dimple would prevent the tube base from sliding into the mast. Pretty sure you'd have to countersink it regardless.
Second, my pitot is a garmin and it comes with mounting holes already drilled and tapped for a #6, but the hole is only about 1/4" deep so I don't have a high level of confidence that I could get a rivet short enough to fit in there, that would still swell up enough to fill a #6 hole.
Plus it seems like it would be a bear to get it apart again if the need ever arose.
As I said above, I think I'll likely just give up on this one, use pan head #6's and move on. The other alternative would be to find a flush head fastener that is less than .050 deep, which probably isn't worth the effort at this point.
03-23-2020, 10:36 AM
  Exactly what I did. Use regular screws and move on. Use the time saved searching for and finding other things I can remove to save weight and therefore get more speed with less fuel use.
