Old 05-26-2007, 11:28 AM
avproavi@aol.com avproavi@aol.com is offline
Default Imron Paint RV-8
Would like to estemate the amount of Imron paint/Primer to do a RV8.
Any reason not to use Imron.?
What color PN would mattahorn white be.(Cessna OEM )
Old 05-26-2007, 01:23 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Since I'm doing this now, for a 6A
I have 1 gallon of yellow, it's that deep yellow like you see on numerous new cars. 1/2 of fuse & all tail surfaces.
2- gallons of gloss gray -- bottom 1/2 of fuse & wings
and a quart of black and white for trim.
1- gallon of primer
can of hardner for the primer, and 3 cans for the paint.
1- gal of reducer
Using Sherwin Williams Genesis 3.5 which has an excellent gloss finish without a clear coat system.
I will have paint left over, even with wasting a quart or two.
L.Adamson
Old 05-26-2007, 01:38 PM
videobobk's Avatar
videobobk videobobk is offline
Default White Imron
I have been told that white takes less paint than some colors (red and yellow I hear are the worst.) My 9A was done in Imron in an off white/very light grey. All other colors were done with vinyl. The man who shot it was VERY good and used about as little paint as possible while still getting a slick job. It took 1 3/4 gallons. I don't recall how much primer/sealer was used. It was done before assembly. BTW, we ended up with less than $3k in paint and labor and a plane I'm very happy with. I did the fiberglass prep, the painter preped the AL.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 05-26-2007, 06:16 PM
KTM520guy's Avatar
KTM520guy KTM520guy is offline
When I paint an RV, I only use Jet-Glo by Sherwin-Williams. Here are the amounts I use.
Primer: 3.5 quarts sprayable. 1 kit of primer, wich is two gallons, is enough for 2 RV's
Base color: 2 gallons of paint + 2 gallons hardener + reducer. I mix in 10-20 percent reducer. To save money, I buy the reducer in 5 gallon cans. You will have paint left over.
Accent stripes: 1 or 2 quarts of each stripe color depending on how much stripe I'm doing.
Hope this helps.
RV-8A builder
A&P mechanic
Aviation Plasticized Pigmented Polymer Application Engineer
Old 05-26-2007, 06:34 PM
KTM520guy's Avatar
Here are a couple of part numbers for matterhorn white.
Dupont Aviation Finishes - 768273
Sherwin-Williams Jet-Glo - 570535
Sorry, I don't have a color chart for Dupont car paint (Imron 5000)
RV-8A builder
A&P mechanic
Old 05-26-2007, 06:56 PM
Brian Vickers Brian Vickers is offline
Default Number of coats?
How many coats are you all applying? One prime, two top? I mean those that are not using a clear coat.
Thanks, Brian Vickers, RV4 finishing
Old 05-26-2007, 07:01 PM
mike newall's Avatar
mike newall mike newall is offline
Check out Ford Diamond White - it is a UK spec color but I am sure you can cross reference. It is very slightly softer than appliance white and looks stunning. I did my Christen Eagle 3 years ago with it and VW Tornado Red
Old 05-26-2007, 08:01 PM
KTM520guy's Avatar
I do 1 coat of primer and 2-3 coats of paint.
RV-8A builder
A&P mechanic
