Old 05-26-2007, 10:51 AM
Steve Sampson Steve Sampson is offline
Default Kohler (aka Essex) Primer fault?
I have an Essex primer on a Supercub. Last week it worked normally, this week it has zero suction. Anyone know what the normal fault mode is? I need a new 'O' ring?
Thanks.
Steve
G-IKON Build log here , or Index to blog here.
RV4 #4478 - Flying since 16th June '08. First flight video here.
Circuits at my 1000' strip.
Old 05-27-2007, 04:18 AM
penguin penguin is offline
Default Balls
Steve,
There are some small ball bearings, held in place by weak springs, that form the valves. You may have a piece of crud under one of the balls? If you have to open it up then you will almost certainly need need to replace any o rings. If you do dismantle it, the springs can shoot the balls a surprising distance, and the balls are small and difficult to find (don't ask me how I know).
Pete
Old 05-27-2007, 07:30 AM
rv9aviator rv9aviator is offline
Small particles were always messing up my Kohler primer on my Champ. Even after I flushed the tank it still would stop up. That little tiny hole in the intake manifold would stop up and keep it from working too.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 05-27-2007, 08:43 AM
Pete/Jim - thanks for the input. Today without me doing any more than a hard stare, its working just fine. For now I think I will leave it alone.
Thanks again
Steve
Old 05-27-2007, 10:05 AM
Could you come over to my shop for a while. I have several things that could use your HARD STARE.
Jim Wright
