Old 03-15-2020, 12:16 PM
airguy's Avatar
airguy airguy is offline
Default Vans ES Dimmer pinout?
Does anyone have the diagram handy for the ES Dimmer module for LED strips that Van sells? Specifically I am looking for the wiring to the four terminals.
Old 03-15-2020, 12:31 PM
rvbuilder2002's Avatar
I think it is printed on the pcb.
Scott McDaniels
Hubbard, Oregon
Old 03-15-2020, 06:52 PM
airguy's Avatar
Not on the one I have, unfortunately - circa 2014
Old 03-16-2020, 10:35 AM
Ralph Inkster Ralph Inkster is offline
Vans ES DIMMER 1.5A instruction page "TE810-1 Cockpit Lamp Dimmer"
With the circuit board facing you, heat sink on top. The 4 connections from left to right:
1- potentiometer control (either wire) and optional ground
2- potentiometer control (either wire)
3- output voltage to lamps
4- input voltage - they show to nav circuit breaker / switch
I don't think this dimmer is specifically for LED unless you gang up the lamps to knock down to the required voltage. The instruction sheet shows voltage output range from 1.2v to 9.5v (12 input voltage less 2.5v)
PM me with your email if you want me to scan this sheet.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
