Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 03-10-2020, 12:20 PM
gregu2 gregu2 is offline
Default "External GPS" no longer displayed on G3X?
I have a Garmin G3X Touch (GDU 460) and GTN 625. Although it used to work correctly, I can no longer select External GPS to use the GTN for navigation - it just doesn?t show ?External? anymore as an option anywhere on the G3X. I updated the GTN Nav database in case it was too far out of date, and updated all the G3X databases, but still no luck. I am using GTN version 6.21 (and 5.2 for GPS/WAAS) and G3X version 8.61. Any ideas on what I should check next? Thanks!
Old 03-10-2020, 03:09 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Default G3X Touch External Navigator
It is interesting that it disappeared like this. We would be curious to see what you are reporting in the System Information tab within the configuration menu, relating to the GTN 625. Would you be able to send us over some pictures of what you are seeing there?
Our email address is G3Xpert@Garmin.com
Justin
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 03-10-2020, 06:00 PM
I'll be able to look tomorrow afternoon - thanks Justin!
