Old 05-24-2007, 07:08 PM
tonyjohnson tonyjohnson is offline
Default cs4-4 rivet hole size
I would think that the appropriate size hole for a CS4-4 blind rivet would #30. When I tried to test fit the rivet in the canopy frame of my 8A, where the skirt will attach, I found that the CS4-4 would not fit in the hole I drilled with a #30 bit.
Other size 4 blind rivets that I have do fit. The CS4-4 is just a tad too large around. Have any of you had this problem? What size hole have you used for the CS4-4 blind rivet?
I should mention that I got the CS4-4 rivet out of a bin labeled for that rivet, that came with the kit when I bought it from another builder. It is possible that the rivet is not actually a CS4-4, but I think it is.
Tony
Tony Johnson
RV8A "Badboy" N12TJ
Treasure Island Florida
Old 05-24-2007, 07:14 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default rivet chart
With my kit 2007 model 9a, i got a rivet chart with to scale pics. It is a perfect way to hold up all the various blind rivets and ensure you know what you have incase the bins got mixed or you find a few on the floor. Someone might have it in pda form. If you get stuck let me know and pm me with a fax number and I will fax you mine. It is a very handy time saver.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 05-24-2007, 07:26 PM
I believe a 17/64" hole is correct hole for a CS-4.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 05-24-2007, 08:41 PM
Default thanks
Bob and Rick,
Thanks for your responses. Rick, I looked and found the chart that you refer to, thanks for the heads up on that.
Bob, After I identified the rivet as a CS4-4 I checked it and found that you are of course correct, 7/64 is the right size.
Thanks again,
Tony
Tony Johnson
RV8A "Badboy" N12TJ
Old 05-24-2007, 09:03 PM
I can take no credit. I actually learned it in the George Orndorff wings video.
Bob Collins
St. Paul, MN.
Old 05-24-2007, 11:55 PM
Pirkka Pirkka is offline
At Van's catalog the correct hole size for CS4-4 is actually 1/8"... Also the name of the rivet would idicate same.
I'm having similar problems: manual calls for MK-319-BS rivets for the difficult parts of the RV-7 rudder and the drawings are talking about CS4-4s. But they both seems to require bigger hole than #40, and to be precise 7/64" hole is likely the size we look for (both) as said earlier in this thread.
I quess it's not so important when these CS4-4 are mostly used to attach fiber glass parts... and blind rivet dimples has very likely 1/8" tip.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 05-25-2007, 01:17 AM
N674P N674P is offline
I know rivets (mainly pulled rivets) sometimes don't fit in drilled holes that they should. However, run the same size reamer through the hole and they fit great!
I can't remember if a CS4-4 should fit in a #30 hole, but if it "should", use a reamer.
Johnny Pruett
VAF #601
-9 fuselage standard kit on hand
Slooow build wings still in progress...
Old 05-25-2007, 05:08 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Measured with a micrometer and cross referenced with a drill index chart, you will discover that a 1/8" (.1250) drill bit is the correct drill bit to prepare a hole for a CS4-4.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 05-25-2007, 10:01 AM
dan's Avatar
dan dan is offline
Rivets are mfr'd with a +/- tolerance.
Drill bits are mfr'd with a +/- tolerance.
Take a drill bit that is at the small end of the acceptable size range. Take a rivet that's at the large end of the acceptable size range. What do you get? That's right, a tight fit. (Same reason you don't want to use a #41 or #42 drill bit on these RVs prior to dimpling...dimple dies could be at the large end of the tolerance range).
Rick, your calipers read 0.12435". Time & tradition have shown you want .003-.004" clearance for a rivet. I'm sticking with #30 (regardless of this discussion). I've never had a problem using a #30 drill bit for CS4-4 rivets, and I don't anticipate a problem popping up now.
Did the original poster try a new drill bit from a different mfr? Did you measure your #30 drill bit? And did the parts shift...even just a few thou...since you drilled the hole? A tiny misalignment often makes the difference between the rivet being able to fit and not being able to fit.
IT'S USUALLY THE SIMPLEST OF THINGS. Check the simple things before deciding to reengineer the hole size.
Dan Checkoway RV-7
Old 05-25-2007, 10:36 AM
Rick6a's Avatar
Dan,
That is certainly your option. I don't know about time and tradition but at McDonnell any blind rivet hole that was .003 over was cause for rejection and the hole had to be brought up oversize. Granted, we are not building fighter planes but out of habit (tradition?) I tend to adhere to the same tolerances on my plane that were expected on the production line.
Sure, a #30 drill bit will work for our purposes but if the builder seeks optimum hole quality, hole preparation with a 1/8" drill bit is the better choice.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
