Lacing tape.
Coating its covered here.
I found that lacing worked way better than zip ties for me. I learned to do it and accessibility to bundles is better, it has higher temperature capability, it is lighter, and way cheaper than zip ties. 99% laced. But - get the good stuff so it is not sticky. I used black. A search will find a post I made with the numbers.
Zip ties are the only way to go for install though, add ties, add wires, cut ties add ties in a seemingly endless routine. Get a thousand. zip, clip, run new wire, zip, clip . . . .
Doing a multi hour lacing session is hard on the fingers to pull tight so use tape or a single glove finger for that. A seamstress tool to pick and cut sewn threads works well to safely cut tight lacing in a finished bundle. Sometimes the flush cutter won't reach.
Bill
RV-7
Lord Kelvin:
