  #11
Old 03-28-2020, 10:48 PM
Driftdown Driftdown is offline
Originally Posted by Cyclone View Post
I had a local auto body shop prime and paint with a GM paint for $5,700. They did a great job. Another $600 for vinyl accents designed and applied by a graphics guy and I?m happy with the end result. After 60 hours of grinning I focus more on looking out of it than looking at it. 😎
Where are those pictures?
Old 03-29-2020, 07:41 AM
wilddog wilddog is offline
Painted my -8 myself. Used 1 gal SPI epoxy primer, 1 gal SPI degreaser, 1.5 gal Nason polyurethane color. Military paint scheme. HVLP turbine paint system. Dreaded doing it but found it to be fun and easy! Except I did develop a skin rash at the end. Estimate paint and other chemicals cost at about $1500. Paint tools were more, DA sander, Apollo spray system, sandpaper, BIG fan, lights, stands, etc.
Old 03-29-2020, 09:45 AM
NinerBikes NinerBikes is offline
How many pounds does a primer and paint job add to the basic 750 pounds of an empty RV-12?
Do you add that in your logs and records book, by reweighing the whole plane, and does it reduce your useful load weight from the 1320#?
Just asking for a couple of 250 + pound friends, kinda close to the limit already.
Old 03-29-2020, 10:07 AM
John Tierney John Tierney is offline
Default RV-7 Prices
I recently called a few SE paint shops (other than FL) and the average quote for my bare RV-7 was $10K from 2 shops, and one other shop quoted $23K for a show plane finish.
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 03-29-2020, 10:26 AM
TomVal's Avatar
TomVal TomVal is offline
Yes, reweigh the aircraft and add the new empty weight and CG to your logbook. Adding paint will reduce your useful load.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 03-29-2020, 12:31 PM
Mitch757 Mitch757 is offline
I internally primed my RV12 during construction and the weight came out to 757 pounds.
After having it painted the weight increased to 771 pounds and moved the CG aft 0.86 inches.
Price was a reasonable $6k and the painter copied the Vans paint scheme.
Old 03-29-2020, 01:33 PM
Cyclone Cyclone is offline
Smile Reply to Driftdown
Working with a local was nice. I brought him components as they were finished and he worked them in his schedule. When I was ready for final assembly and inspection I had a finished and painted aircraft. Wheelpants are on order.
RV12 - Flying August 2019
Restoring 1967 Ford pickup - no amount
of money will make this thing fly.
"I have enough money to last me for the rest of my life.
As long as I don't buy anything"
Old 03-29-2020, 02:03 PM
funflying funflying is offline
https://postimg.cc/LgS5CJTT
https://postimg.cc/ZBvJhpjm
Here is my relatively simply paint job and I had it done at a local custom car shop in Denver. 8K when all done. About twice as much as I?d hoped.
The other is a friends RV7 and his was a 14K job. He said the White is some special pearl and was more expensive than the other colors. He had it done at Meadow Lake Airport, East of Colorado Springs KFLY.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 03-29-2020, 03:24 PM
Thank you Sir . . . that's a pretty RV-12!
Old 03-30-2020, 06:34 PM
Thanks, Mitch. Depending on the paint scheme and how much white base gets painted over with color, probably 20 to 25 #s then.
