  #11
Old 03-06-2020, 07:24 PM
Stockmanreef Stockmanreef is offline
My original engine mount was so bad on my 14a that I had to use a wrench and screw the 6th bolt into place. The first 5 slid easily into place. At first I had no idea what the heck was wrong, then I put it on a granite counter top and one of the mounting brackets was way off. I posted this a while back:
http://www.vansairforce.com/communit...t=engine+mount
I sent pictures Vans and they replaced the engine mount. If you want to see the pictures, I just posted them on my facebook page (Ken's RV-14: https://www.facebook.com/Kens-RV14-632288410496405/).
I am not sure how bad it has to be for the mount to be replaced, but I would consider removing and putting on a flat surface to see how bad it really is before you torque down the bolts. Do you really want that kind of constant torque on the bracket?
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
Old 03-07-2020, 03:58 PM
rapid_ascent rapid_ascent is offline
Yeah 0.004 isn?t very much. I would just take a file to it and file a little bit off the lower side. If you inspect the mount closer it may just be a small spot. Also make sure the mount ant the firewall are both deburred.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 03-07-2020, 04:15 PM
Plummit's Avatar
Plummit Plummit is offline
The problem with filing down the mount is that you may end up with that "leg" not even touching the firewall at all. Once you start modifying the mount you own it!
-Marc
RV-10
N814RV
2020 Donation Made
Old 03-07-2020, 04:20 PM
The question is: What is the gap in the resting state--not torqued?
I bet the gap when sitting on a flush surface is much more. Thus there could be a lot of stress on the joint since the gap closes upon tightening.
Ken Stockman
Midland, MI
N73XP
Old 03-07-2020, 05:19 PM
Valid point about torqued down versus resting.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
