  #21
Old 03-12-2020, 04:20 PM
terrye terrye is offline
Default Looking for feedback on RV-7A Garmin panel design
1. Your ELT switch is directly ahead of the passenger/co-pilot stick AND right next to the panel mounted co-pilot PTT switch. Suggest moving the ELT switch to the right of the breakers and move some of the breakers down where the ELT switch was.
2. I said this once already. Check for interference with your center mount radio stack and the especially the GTN 650 with the F-7108A fwd fuselage rib and the F-7108B fwd fuselage angle.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 03-12-2020, 05:52 PM
David Carter David Carter is online now
Originally Posted by RV7A Flyer View Post
Same for boost pump and flaps. Consider inadvertent activation...flaps deploying at high speed? Boost pump *in*activated accidentally during takeoff or landing?
Thank you for the feedback. I will think about these items. Flaps are controlled by the GAD 27 which will be configured to lock out deployment above Vfe. Boost pump mitigation plan is currently an annunciation on the G3X screen via a discrete input. If it becomes a problem I can always remove or disable the stick switch.
David
RV-7A Slider N87BP (bought flying in 2018)
Superior XP-IO-360
AFP Fuel Injection & Dual SDS CPI-2 ignition
KLZU - Lawrenceville, GA
2020 Dues Paid
Old 03-12-2020, 06:01 PM
Originally Posted by PilotjohnS View Post
I am not sure about the avionics master anymore. Garmin has a nice box (Gad 27) that does not let the avionics brown out during start and provides voltage stabilization. With this box, is there still a need for an avionics master?
From what I?ve been able to gather on VAF & via discussions with multiple installers, there is no need for the avionics master even without the voltage sag protection in the GAD 27. Modern avionics have built-in protection.
In fact, the avionics master just adds another point of failure.
I have a GAD 27 in this design but primarily as flap, trim, and lighting controller.
The two leftmost switches on the bottom are BATTERY MASTER and AVIONICS BATTERY. BATTERY MASTER controls the main battery contractor. AVIONICS BATTERY controls output from the IBBS avionics backup battery to critical pieces of avionics.
David
Superior XP-IO-360
2020 Dues Paid
Old 03-12-2020, 06:04 PM
Default Thanks!
Thank you for the feedback. I will look into both of these items.
David
Superior XP-IO-360
2020 Dues Paid
Old 03-12-2020, 06:08 PM
Default First time on the VAF front page!
I just saw that my revised design post on this thread from earlier today made the front page. I?m now feeling guilty for not yet paying 2020 dues. Scurrying off to rectify that now. Worth every penny for the feedback on this thread alone.
David
Superior XP-IO-360
2020 Dues Paid
Old 03-12-2020, 06:56 PM
Jpm757 Jpm757 is offline
8 functions on the stick? That's nuts!
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 03-13-2020, 07:33 AM
It's down to 7 now! Perhaps not as crazy as it sounds when you take into account that 4 of these functions are on just two switches:
- hat switch - pitch trim up/down, com select, com flip/flop
- trigger switch - PTT
My goal is to keep HOTAS as much as is reasonable.
David
Superior XP-IO-360
2020 Dues Paid
Old 03-13-2020, 10:01 AM
Bavafa Bavafa is offline
This is a very nice panel, congrats.
My thoughts:
- Panel real estate is very precious, so I would not waste it for the USB charger, you already have one in your audio panel and if you need any additions, perhaps between the seats or behind a panel.
- Maybe moving the ELT control closer to you than passenger.
- If you can swap the G5 and SDS, since G5 will be more useable for both sides and gets used more than the SDS.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 03-13-2020, 01:55 PM
Default Thanks!
Mehrdad - thanks for the ideas.
I've had a couple of people make this suggestion. Keeping it on the panel simplifies the wiring, but I'm open to alternatives. Does anyone have pictures of their USB chargers in alternate locations?
I will look into both of these. The G5/SDS swap is particularly interesting & you are the first to suggest it.
David
Superior XP-IO-360
2020 Dues Paid
Old 03-13-2020, 03:59 PM
PilotjohnS PilotjohnS is offline
Default My opinion
My opinion is to leave the G5 where it is. If you have ever seen a G5 in real life, I think there is a lot of info in a tight spot. In addition, I will be using it only for a back up. If I am relying on the G5, my flight has gone to the pits, I am stressed, and I am doing things I dont practice often. In this case, the last thing I want to do is to be twisting my head looking at the G5, looking outside, and trying to troubleshoot; I want the G5 in a place that is easier to look and close enough to see all the symbology. JMHO
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 5% in work
Firewall Forward 5% in work
www.pilotjohnsrv9.blogspot.com
