Old 02-26-2020, 08:20 AM
Dan B Dan B is offline
Originally Posted by gasman View Post
Here is an air filter test. See how your K&N filter rated..... shocking
https://www.nicoclub.com/archives/kn-vs-oem-filter.html
I am still looking for a replacement. Not easy to find.
Does anyone have experience with the K&N Airforce foam pre-cleaner?
Dan Burdette
Skyview, ADS-B, Garmin 420W, TT Gemini AP
RV-9A, IO-320, E-Mag
Guthrie-Edmond Rgnl, OK (KGOK)
________
Old 02-26-2020, 09:35 AM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Originally Posted by ljpgrif View Post
After 3 oil changes, my oil analysis from Blackstone reports that the silicon level is in the high 20's ppm. The filter has been inspected and cleaned/oiled after every oil change. First report was 15 ppm...then 22 ppm and now 29 ppm.
I found no filter leaks and filter looks good.
Talked to K&N company on this and they told me right off that the filter is NOT for planes. Talked to Vans and they said that they never had a issue.
Has anyone had this problem before?
Any other filter that I can try?
Larry
N687VR
Just noticed that you mentioned the E-3260. Which plane/engine combo uses the E-3260? I went back to check to make sure I just bought the correct one, mine seems to be E-3450 for the RV-8 with 0-360.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
