I am finalizing my schematics prior to starting wiring and am working on connectivity diagrams between the following systems D100, D120, GTX-327, SL-30, ADI II A/P and Garmin 496. It seems as if there are only two GPS inputs into the Dynon suite and even then you have to switch the inputs between the 496 and the SL-30 rather than have both online simultaneously. Also there iseems to be only one output from the 496 to drive either the Dynon or the A/P.
Can I wire multiple data streams from the 496 (ie. create a GPS stream data buss) and how have others connected the SL-30 and the 496 into their Dynon systems. Do I have to include hard wired switches to select between the various functions and switch the 496 between the A/P and the Dynon?
Also anyone have the SL-30 wiring schematic and the current draw/fuse size requirement.
