View Poll Results: Have a RAC SPD-1 installed in your elevator trim circuit?
Yes 9 37.50%
No 15 62.50%
Voters: 24. You may not vote on this poll
Old 05-22-2007, 02:05 PM
randylervold's Avatar
randylervold randylervold is offline
moderator
Default Servo trim speed controller installed?
Based on the experience of most people with RAC elevator trim servos I installed a RAC SPD-1 speed controller on the trim circuit in my RV-3B. My installation is a bit custom and may have different travel rates due to mechanical linkage differences than the newer RVs. When I powered it up I found that with the speed controller dialed up to its fastest setting it takes 15 seconds for the trim to go from neutral to either full up or full down, and 29 seconds for full up to full down. I understand you don't want it too sensitive in cruise, but this seems a bit slow to me.
I'd like to know how many guys installed the SPD-1 versus not, and if anyone has timed the travel of their systems please post the results for us all to compare.
Thanks!
Randy Lervold
RV-12iS, empennage/tailcone complete, wings currently, fuse in box
RV-3B, first flight 2007 - sold
RV-8, first flight 2001 - sold
Old 05-22-2007, 03:14 PM
moderator
More data...
Voltage to the servo without the speed controller measured 12.05 volts. Voltage with the speed controller in the circuit but turned up to full fast was 10.52 volts meaning that it drops it 2 volts when wide open. The difference in speed was noticable although I forgot to time it for comparison. Turning it down showed progressive voltage reduction until the servo wouldn't move. I think I might need to remove it from the circuit altogether.
You'd think when it was turned up full fast it wouldn't attenuate the voltage but that is not the case. Too bad, what if say 11.0 volts was the perfect setting, you can't get there.
Randy Lervold
Old 05-22-2007, 04:54 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Wished I had
Hi Randy,
With over 200 hours on my 7 now and most of that Cross Country, I wish I had installed the "rate" switch on the elevator trim servo. At cruise one bump is often too much. The Trutrak trim indicator is somewhat hard to nail with only the fast rate.
My neighbor is building a 7A and I convinced him to do the rate switch. It only added a couple of hours of work to install and I'm sure it will be beneficial.
Mark Chamberlin took another approach and installed a rheostat on his panel for the elevator trim servo. He can set the rheostat which sets the speed when the trim switch is activated. Also a great idea.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 05-22-2007, 05:57 PM
kentb's Avatar
kentb kentb is offline
Default Hi Randy
My servo voltage is set at close to 7 volts with flaps up. It works well for my 9A.
I initially had it wired upside down and could not understand why when in cruse flight it was always to sensitive.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 05-22-2007, 11:03 PM
rv8180 rv8180 is offline
Default Rheostat
Darwin,
Could you get ordering info on the rheostat, or put me in touch?
Thanks!
Roy C Lewis Jr
Jax, Fl
RV8QB
Lyc AEIO-390
Catto 3
Dual GRT
Firewall forward
Old 05-22-2007, 11:08 PM
GAHco's Avatar
GAHco GAHco is offline
Default I did not vote
I did not vote, I ordered the speed controllers yesterday and they are coming tomorrow.
I will be installing them based on a large amount of comments on this forum of people who wished they would have.
RV6
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 05-23-2007, 01:27 AM
dan's Avatar
dan dan is offline
Randy, it looks like you installed a 2-axis autopilot. Imho having altitude hold helps rationalize NOT needing the complexity/cost/weight of a speed controller. Just my 2 cents.
Dan Checkoway RV-7
Old 05-23-2007, 06:10 AM
db1yg's Avatar
db1yg db1yg is offline
I have an RV9a with TruTrak a/p with altitude hold. I initially flew my plane without the speed controller and found that the Ray Allen elevator trim was far too sensitive when at cruise speed. You had to learn to "stab" at the trim switch for minimal ele movement--and it was still usually too much. I installed the speed controller (a couple of ounces additional wt) and adjusted the speed down about 1/4 to 1/3 and it is now very easy to obtain good trim in all flight configurations. Please note that I have the TruTrak AlTrak altitude hold which does not correct out of trim conditions when engaged--therefore you must get good trim in cruise before engaging the a/p.
Given my experience, even if I had an a/p with trim adjust I would still install the controller to make it easier to manually adjust when the a/p is not engaged. YMMV.
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 05-23-2007, 07:26 AM
moderator
Default Good info, thanks!
Dan, it weighs almost nothing (1-2 oz.?), costs $39, and can easily be eliminated from the circuit the way I wired it so I didn't see much downside.
Interesting that the poll shows more guys do not have one yet all the comments seem to indicate it's necessary. Good info, I'll fly it the way it is and see how it feels. My conern was in doing go-rounds where it might take a long time to get from landing configuration trim to climb. Small plane though, it can't be too tough to just hold some stick pressure while the trim catches up.
Thanks to all for the comments!
BTW, I'm transporting it to the airport this weekend and hope to be airborne during the first half of June. Inspection is scheduled for 6/1 if my prop is returned from WW in time.
Randy Lervold
Old 05-23-2007, 08:50 AM
f1rocket's Avatar
f1rocket f1rocket is offline
I put one in the Rocket and have it set at its slowest speed, and it's still too fast. All it takes is one little bump of the switch to change the trim. The A/P likes the airplane trimmed hands off as it seems to be smoother than when there is pressure on the stick.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
