Old 02-09-2020, 12:59 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Default Flap motor arm cover
A good friend and RV-8A driver, Tom Doran, came up with this slick cover. It needs a #8 nutplate on the arm rest and a #6 nutplate on the rear seat bulkhead. It shares a #8 screw on the top aft of the side panel cover.
Attached is a template I used to make this out of 0.032? aluminum.
Carl
Bolting stuff on for the last time.
Old 02-09-2020, 02:34 PM
TShort TShort is offline
Looks good!
Do you have a higher res version of the template or a .pdf
That one is small enough that I can't read the writing, even when opening in a new tab and zooming in...
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 02-09-2020, 03:52 PM
scsmith scsmith is offline
Looks a lot like mine. I made mine extend just a little farther forward, to pick up that second screw in the lower side panel.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 02-09-2020, 04:54 PM
Thomas,
PM me your email address and I'll send a scan of the template.
Carl
Old 03-02-2020, 07:22 AM
PhatRV PhatRV is offline
Sent you a PM.
Thanks.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Done. Fiberglass 80%
Avionics Installation -- 90%
Firewall Forward -- Cowl completed. Baffle 90%
Electrical -- 90%
Donation paid through 2021
