Old 02-09-2020, 10:11 AM
kbalch's Avatar
kbalch kbalch is offline
Default New RV-14A Build Site
While my project is nearly done (inspection scheduled for 2/20/20), I've only recently completed a build site for it. Prior to this, I've been posting photos to my personal Facebook page and sharing those posts with the Vans RV-14 group.
The URL is: RV-14a.com
Take a look; I hope it's of use to the many -14A builders still working on their projects.
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - Sold
RV-14A.com
N114KB Build Site
Old 02-10-2020, 05:04 AM
mturnerb mturnerb is offline
Just checked it out - well done!
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 02-10-2020, 05:57 AM
carlrai's Avatar
carlrai carlrai is offline
Default Well done Ken
This will be an excellent resource when I get started on the fuselage in a few months.
Carl Raichle
Lutz, FL
RV-9A N194CR
RV-14A Under construction
Based at KZPH
AA4SR
Old 02-10-2020, 09:28 AM
AlexC AlexC is offline
The site looks great, Ken! Your posts on Facebook and now this site have been extremely helpful in the construction of my RV-14A.
_Alex
Alex C.
2021 RV-14A: Flying as of 4/13/21 - 70hrs so far
1999 Cessna 182S - Sold
Old 02-10-2020, 10:20 AM
kbalch's Avatar
Thanks, guys, for the kind words.
Ken
RV-14A.com
N114KB Build Site
Old 02-10-2020, 10:53 AM
BVD's Avatar
BVD BVD is offline
Default My day is accounted for...
Well I know what I'll be doing all day today lol!
Bill VonDane (BVD)
CO15 - Elbert, CO
RV-8A - Flying
CH750 STOL - Building
Old 07-13-2021, 11:17 AM
Foam-the-runway's Avatar
Foam-the-runway Foam-the-runway is offline
Beautiful writeup and work on plane.
Being experienced in building both an 8 and 14 how would you compare the projects? I know the 14 has match sized holes. Does that give a noteworthy drastic advantage over building the 8. I ask because those are the only two models I'm interested in. I keep flip-flopping back and forth. I'm getting close to making the purchase. Any input you can provide would be greatly appreciated.
1978 C-172N
Toolbox kit
Airfoil kit
3 x EAA workbenches
Haven't decided which RV to build yet.
Assembling tools att...
Old 07-13-2021, 03:49 PM
kbalch's Avatar
Hey Gary,
Thanks for the kind words; much appreciated!
With the understanding that my experience with the -8 is 20 years old and the kit has probably changed at least somewhat since then, here are my thoughts:
The -8 kit came with prepunched skins, but none of the structure was correspondingly prepunched. It required jigs for the empennage, wings, and fuselage. While all of the steel parts came welded and powder-coated, the vast majority of the smaller aluminum components had to be fabricated from raw stock. Opening each kit crate was a shock as one contemplated the vast array of AL angle, plate, and bar stock. Each section of the instructions began with fabricating many of the necessary pieces prior to fitting and assembly. One became adept very quickly at reading and understanding the plans.
The -14 kit, on the other hand, is that most modern of creations. It's practically a Snap-tite model. All of the skins and nearly all of the substructure is prepunched, much of it to final size. No jigs are required; by definition, if everything clecos together, the structure is straight. Offhand, I can't think of a single component that had to be fabricated from raw stock, some bandsawing of edges in a few cases (and cutting of piano hinges to length) notwithstanding.
That said, neither project presented any insurmountable issues. Van's, as they've always said, sells an airframe kit, not an airplane kit - and by the time you've finished, you'll have mastered any number of new skills. I think that the -8 kit would be a big surprise (not in a good way) to someone whose only experience was of the -14 kit, but if you're open to the adventure, I wouldn't hesitate to build the -8 if that's the airplane which grabs you.
You didn't ask for my comments on the two airplanes, only the kits, so I've refrained from doing so. Suffice it to say that you'll thoroughly enjoy flying either model, though they have very different primary missions. Which is best for your mission, only you can say.
Best,
Ken
RV-14A.com
N114KB Build Site
Old 07-21-2021, 06:18 PM
rvbuilder2002's Avatar
The RV-8 kit has changed a lot in 20 years.
It is now nearly fully prepunched (including all sub structure) but not quite to the extent of the RV-14 and not to final size
Scott McDaniels
Hubbard, Oregon
FAA/DAR
