  #11
Old 05-23-2007, 07:34 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Originally Posted by gasman
Can someone with carb temp tell us what temp. increase you get. I can only see about a 20 rpm drop with carb heat. Is it enough?
I can't answer that, although I have found many RVs have no drop at 1700 RPM. I get a drop of 30 or 40 but the airbox has cracked several times. Glad to hear that Randy is working on that.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 05-24-2007, 01:27 AM
Walt's Avatar
Walt Walt is online now
Default I feel pretty good then...
Originally Posted by Ironflight
I figure that at 475 hours, I have to expect a little wear from vibration, so I guess I'm doign better than many!
Paul
I'm about 550 hrs and no problems at all with the airbox (carb). I added some doublers to the mounting plate when I built it to prevent cracks and I guess they are working . I have had no problem with the heat door either (I've never used carb heat except the occasional pull on the lever to see if it still operates). I check these items whenever I pull the cowl off (which is pretty often) and so far so good.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-24-2007, 07:16 AM
Scorch Scorch is offline
Super Moderator
Larry,
Didn't mean to imply that Randy had actually made this fix to your airbox yet - when I was over there the other day, he basically used your engine as a training aid to show me how his idea could work. If my blankety airbox keeps breaking, I may be the first one to actually try it.
Looks like he's doing some great work - when he's done I think you're going to have the strongest RV on the planet.
Good to know not everyone is having issues with these airboxes. There's hope.
Ross Burgess
DFW area
Bought flying RV-6
Old 05-24-2007, 07:43 AM
Ironflight's Avatar
VAF Moderator / Line Boy
No Scorch, it's really just you....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
