Solder Shields - when & where to use them?
I've been doing a little reading on solder shields and they look like great little gizmo's to use on shielded wire. However, I'm not quite sure when I should use them.
For example, the Lightspeed ignition installation shows connecting the shields across the breaker and switch. Would this be a good place to use them?
Where else should they be used? When you use them do you normally use the ones with the built in pigtail? Where would one's without the pigtail be used?
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
