Old 02-04-2020, 11:38 AM
scsmith scsmith is offline
Default Antenna location for Stratus 3 ADS-B receiver
I'm curious where people have put the ADS-B antenna in their RV for a Stratus 3 or other ADS-B in?
It is supposed to have visibility to the ground to receive signal from towers. It is a short little "rubber duck" antenna on an elbow fitting to the cable. The Stratus comes with a suction cup to put it on a window of a cabin-type airplane like a Cessna.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 02-04-2020, 11:51 AM
Saville's Avatar
Saville Saville is offline
I mount the Stratus 3 onto the canopy at around shoulder height on my left. I then run the antenna up high on the canopy bow. Seems to work ok
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 02-04-2020, 12:09 PM
BH1166 BH1166 is offline
Default Scout
Before I installed EchoUAT, I used a little ForeFlight Scout , suction cupped the all in one unit just above panel in upper corner. Worked really well. I say all this as I don?t think it matters that much where it goes, it will work fine as long as you don?t intentionally hide it.
Butch
RV6A Purchased N72TX
2020 Dues Paid
Old 02-04-2020, 01:30 PM
RV8JD's Avatar
RV8JD RV8JD is offline
When I had a Stratus 2S in the RV-8, I mounted the unit on the mid cabin cover (F-881-1). I mounted the external ADS-B IN antenna near the side bottom corner of the windscreen on the right side using the supplied suction cup and the ADS-B antenna extension cable. It seemed to work fine there.
I also placed a small external GPS antenna on the glareshield.
Carl N.
Arlington, WA (KAWO)
RV-8, 790 Tach Hours
(Pic 1),(Pic 2)
- Out with the Old, In with the New
(Pic)
RV-8, 1938 Tach Hours (Pic 1),(Pic 2) - Sold
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 02-04-2020, 11:43 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
I have a Stratux velcro'd to the right side fuse just beside the front seat. Both antennas are attached to the Stratus box and they both are right above the side of the fuse. That location doesn't bother the canopy or anyone getting into either seat plus have unlimited view outside toward any plane or tower. From there I wrapped the GPS antenna up the front seat mount to the top so it sits right behind the front seat on top of the frame.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
