Old 02-03-2020, 10:36 AM
dwranda dwranda is offline
Default Tips needed for dimpling completed firewall
I am trying to hang my oil cooler and would like to put nut plates in so removal will be easier in the future. Want nut plates behind everything on the firewall to ease removing from the front only. I would need to dimple the firewall where there is the angle support behind it. Obviously I can't just use the dimpler that uses the rivet puller. Is it OK to countersink these even though the firewall is so thin?
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid April 2021
Old 02-03-2020, 10:58 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
The short answer is no - just use AN3 bolts and nuts.
But - I always use a piece of 0.063? 3/4?x3/4? angle to mount the cooler, the angle then is bolted to the firewall where, as you suggest, there is supporting structure on the cabin side of the firewall. If you still want to use nutplates, put the nut plates on the angle, the angle still bolted to the wall.
Carl
Old 02-03-2020, 11:14 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Ditto what Carl said
You want to be able to remove the oil cooler from the mounting angles. Put the nut plates on the 3/4" aluminum angle corresponding to the holes in the oil cooler flanges (6 total -- 3 top, 3 bottom).
I used AN525 screws to mount the ends & middle of each mounting angle to the firewall and underlying stiffeners. The AN525 has a lower profile head than the AN3A bolt so I could get the oil cooler and its fiberglass plenum right up to the apex of the mounting angle without interference.
Cheers!
Brian Decker
RV-7 (Flying)
Old 02-03-2020, 11:43 AM
N941WR's Avatar
N941WR N941WR is offline
I used a pop rivet dimpler to install platenuts. Then you can bolt it to the firewall.
Honestly, I would reinforce the #4 baffle and mount the oilcooler there, as thousands have done.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-03-2020, 12:19 PM
Brockster's Avatar
Brockster Brockster is offline
I don't think other posters understood your question. Because it appears the aluminum support angle is already riveted to the firewall you are asking if countersinking for a flush rivet to hold nut plate is an option. It isn't. Essentially this would remove the stainless metal layer completely. If you could still remove the aluminum support angle and install the nut plate in that alone there by causing the flush rivets sit under the firewall skin. As long as nut plate would never need to replaced this would work. I would use an AN3 bolt along with a nut and move on. You won't really need to be removing it once installed.
Paul Dannebrock
RV-9A, Flying
Old 02-03-2020, 12:50 PM
Thanks guys I was hoping there was some procedure I didn't know about but looks like I will just be using nuts and bolts. I figured the oil cooler mount wasn't something I was going to be removing very often or maybe even never but thought I'd look into it anyway.
9A in progress
Old 02-03-2020, 03:45 PM
rzbill's Avatar
rzbill rzbill is offline
Don't give up yet. Depends on how bad you want a nutplate there.
You have two flush rivet locations available already. Drill them out. Make a thin plate with holes for those two rivet locations. Put a nutplate on that plate. Rivet this new plate into position. Done.
You are essentially making a special nutplate with long ears to reach the flush holes you already have.
Bill Pendergrass
ME/AE '82
Old 02-03-2020, 04:21 PM
Duh yeah why didn't I think of that. If I decide I really want the nutplate there I will do it that way.
Thank you!!
9A in progress
Old 02-03-2020, 05:31 PM
Taltruda Taltruda is offline
Default Clickbond
Wouldn't this be a perfect candidate for clickbond fasteners?
https://images.app.goo.gl/bkWGJH1H7qste6Y56
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 02-03-2020, 06:08 PM
agent4573 agent4573 is offline
for my own curiousity, would a doubler plate and riv-nuts work? Put the doubler on the inside of the firewall and then use the riv-nuts to hold it in place and mount the oil cooler with a bolt?
www.rv7build.com
N69ER - reserved
