02-08-2020, 09:00 AM
Folding tie down rings
Can someone please make folding tie downs for our RVs? An aerodynamic blister or fairing shape with a center bolt and a fold down ring. Google folding tie downs or folding race hooks and there are lots of ideas. The ones below are just rough ideas.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
02-08-2020, 05:06 PM
25 kts easy
Have these on my plane, adds 25 kts easy, plus they look cool.
http://www.aircraftspecialty.com/Sta...e%20Downs.html
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Need:
Paint?
Serial#12-0864
N112DR
https://youtube.com/c/CraftingN112DR
VAF donation made for 2020
02-08-2020, 05:19 PM
One thing about leaving them out: mud daubers! At least in Florida where I'm located.
Had a heck of a time getting one screwed in when I needed it. I don't carry a 3/8-24 tab (or whatever the thread is) with me.
Perhaps I should look into a plastic plug of some sort.
Finn
N214FL RV-4 -- Building
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
02-08-2020, 06:31 PM
Short grip length AN45 eye bolt. I think it?s an AN45-4 (or -5) from memory.
https://www.aircraftspruce.com/catal...eboltsan45.php
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
02-12-2020, 01:04 PM
Originally Posted by Charlie12
When I occasionally tie down outside I put the ropes thru the wingtip hand holds. Seems to work fine.
Probably would work fine in winds wheret the only concern is about the airplane getting turned/moved slightly, but in instances where weather is severe and you really hope to keep a light airplane like an RV-12 from flying out of it's tie down spot, I would not recommend using the lifting handles on the wing tips.
They are not designed to take anywhere near the loads that the threaded tie down anchor can.
Scott McDaniels
Hubbard, Oregon
02-12-2020, 01:44 PM
One of the reasons to remove them is the potential issue with dissimilar corrosion; steel threads in an aluminum fixture.
For that reason, I do not leave them in when flying.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
02-12-2020, 04:39 PM
corrosion
The potential for corrosion is ALWAYS there unless the two metals are the same. Looking at the galvanic corrosion charts, Cad plated steel is generally not an issue with aluminum. Stainless can be an issue, as it is further from aluminum on the chart and Titanium is even further. Using aluminum rings would be bad due to the lack of comparable strength and the tendency for aluminum on aluminum tends to gall very easily. Using stela's or even stainless with a light grease or anti seize is probably the best balance between strength and potential corrosion issues...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
03-02-2020, 03:34 PM
plastic plugs
In line with Finn's reminder about mud daubers, I searched around online and did manage to find white plastic push-in cap plugs that fit the tiedown holes and protrude very little on the outside. I bought several spares but the originals have stayed in place for 3 1/2 years.
I agree with the recommendation that it would be unwise to use wingtip lift handles to tie down in strong wind. I taught structural design for 30+ years and the relative strength observation makes perfect sense. With an airplane as light as an LSA I don't do anything in strong wind.
RV-12 #120768, first flight Sept. 2016
245 hrs as of 2/1/2020
03-02-2020, 06:49 PM
Standard Tie Downs work
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
