Old 05-20-2007, 09:49 PM
JoeLofton JoeLofton is offline
Question Paint Cutter?
Any ideas on how to make a clean cut of the paint around flush rivet heads prior to removing the rivets? I'm replacing one of the upper cowling-to-firewall piano hinges on my RV-3, which requires drilling out the -4 flush rivets.
Avery sells a paint cutter for #10 screws, but nothing for rivets.
Thanks...Joe
Old 05-21-2007, 06:37 AM
Mel's Avatar
Mel Mel is offline
Not sure that the "Avery" style paint cutter would work on rivets. The cutter needs a hole for centering. However, on the other hand, a rivet should not turn during removal as a screw does, so drilling out rivets should not be a paint problem.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-21-2007, 07:35 AM
mark manda's Avatar
mark manda mark manda is offline
I can understand why you're concerned.
I was at a Airshow RV flyin at Chino the last two days.
I was checking out the differnet airplanes and whether they had painted fuel tank screws or SS unpainted.
On a project of mine; they are all primered and I was wondering what to do pior to sending it into the paint shop. I assume primer is real soft and won't crack...
I saw a nice plane with cracked paint around several tank screws, not good.
It sounds like worst case-- you might have to do a repaint on the area and color sand.
