Avionics Relay
you are right in that you hold power in the off position & the relay fails to power on. This assumes that your power feed come from the main bus that is fed via the main battery contactor. The avionics master sw needs to be a single pole double throw for this to work.
Stephen Reynolds
RV7 N570Z (Reserved)
Finish
Eugene Oregon
London England
Newcastle Australia
