Old 01-28-2020, 06:56 AM
svyolo svyolo is offline
Originally Posted by JohnHolman View Post
Mark,
That makes sense - there's a lot involved here. The Glastar does have 2 small (1 quart) header tanks, one for each wing tank (all gravity fed). That would probably simplify the return fuel lines somewhat, but it's still going to be pretty involved...
Thanks for the feedback!
EFII's fuel system layout is a fuel rail layout. It absorbs a significant amount of heat as it loops around the engine because of this. Their install manual recommends a minimum header tank size of at least 3 or 5 gallons, I can't remember which.
There are some significant fuel system requirements for the current EFI systems on the market. On an RV or most other low wing it is actually simple. On high wing it should be simple, but actually isn't.
I am not familiar with the Glastar fuel system, but I bet I can take a good guess.
Old 01-28-2020, 07:16 AM
JohnHolman JohnHolman is offline
I've actually decided to switch to Ross Furman's SDS EM-5 system, which is slightly different from Paisley's EFII system. Not sure about the differences in installation yet, but i may try to either use the existing (small) header tanks, or install a single, larger header behind the firewall. But, i'm going to find a qualified, experienced installer to assist with both the planning and the installation...
John Holman
Canton, GA
Flying JetProp & Glastar Taildragger with O-360 & CS Prop
interested in RV7
