Old 01-19-2020, 12:02 PM
laz laz is offline
Default retread size
I know this has been beat to death, but My 8 will need new tires soon, (300+ landings) and I am planing a trip to Alaska and want some advise.
My 8 came withe Aero Classic tires. I have no complaint other than they had to be rotated because of excessive wear on the outside. My wheel pants are a tight fit.
here are my questions.
1. Are the Dresser Retreads going to be larger than the Aeroclassic tire ?
2. Friend uses Airhawk what is the latest word on that.
3. The Retreads come in a 5 ply and "monster"10 ply rated tire.
4. What tube to buy ?
My 8 uses sam James wheel pants and they are a tight fit so size does matter. A lot of post say they use the retreads, but there are a couple on Dressers sight.
Old 01-19-2020, 12:36 PM
Bavafa Bavafa is offline
My experience with retreads has been that they are definitely larger and I had to open up my wheel pants on the 7A to make sure there is enough clearance. they are also heavier but last much longer.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 01-19-2020, 01:03 PM
Jpm757 Jpm757 is offline
Going to Alaska-get the bigger 380?150 tires!
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 01-19-2020, 01:20 PM
laz laz is offline
those are little big for my 8. I plan to try and stay on pavement. Maybe buy some bush flying time in a supper cub or something.
I just want a decent set of tires. Not trying to save money. I just want something better than the Aero Classic. Its not bad but thought maybe there was something better.
Old 01-19-2020, 01:53 PM
If you don't want to save money get Michelins, great tires, but pricey$$$.
Jake
Old 01-19-2020, 06:46 PM
rongawer rongawer is offline
Monster 500x5 retreads are 10/32" vs the 8/32 on standard tires, so you do need to open the forward and aft ends of the wheel pant a little if you have them.
You might also consider Wilkerson Tires; I used to get my tires from Desser, but they tend to be out of 500x5 retreads a lot, whereas Wilkerson offers free shipping and about the same price with very friendly service. Wilkerson retreads are 10/32 as well and a very hard tread that lasts a long life. For reference, I got about 450 landings on my last set.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
Old 01-19-2020, 07:40 PM
laz laz is offline
Those dimensions are of the thickness ?
Old 01-20-2020, 09:14 AM
I believe those dimensions are of the depth of the groves in the tire. But the sets that I had received in the past were more than 1/8" taller than the original but once I opened up my wheel pants, it worked for the following pairs after that. So, it is a one time thing deal.
Mehrdad
Dues paid
Old 01-20-2020, 09:39 AM
It’s the tread depth. At 10/32 vs 8/32 OEM tread depth, the overall height would be 4/32 taller than OEM tires, so yes 1/8” larger tire diameter
Ron Gawer
Old 01-20-2020, 07:36 PM
laz laz is offline
Thanks to all for your help.
