Old 01-19-2020, 11:29 AM
Draker's Avatar
Draker Draker is offline
Default New T-handle push-pull failure
A while ago, I bought one of those push-pull handles that are T shaped with the push-button lock in the middle. Finally got around to starting to install it and I noticed that the locking function does not work. Moreover, the button (with a rod attached to it) is free and simply falls out of the unit! Before I go through the hassle of returning it, does anyone know if this is a common failure that I can fix myself?
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 12/16/2019
RV-7A (N12VD): Empennage and wing kits complete minus fiberglass, fuselage and wiring complete. Canopy complete minus fiberglass. Waiting for the engine to come!
Old 01-19-2020, 11:40 AM
rapid_ascent rapid_ascent is offline
Ryan,
I thought I read somewhere if you pull the handle out too far there is a ball bearing that can fall out. I?m not sure where I saw this but it would be pretty easy to do if you are not aware of the potential problem. Maybe do a search to qualitfy my memory.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 01-19-2020, 12:01 PM
rvbuilder2002's Avatar
Originally Posted by rapid_ascent View Post
Ryan,
This is correct.
Did you possibly pull it out quite aways (beyond 2.5 inches or so) at some point?
Scott McDaniels
Hubbard, Oregon
Old 01-19-2020, 12:39 PM
Draker's Avatar
BINGO that was it. Looked around on the shop floor near the last place I was playing with the handle and lo and behold there was a little ball bearing sitting in a corner! Thank you, gentlemen.
Ryan Drake
Livermore, CA
Donated 12/16/2019
Old 01-19-2020, 12:51 PM
gofly gofly is offline
WOW! You're a lucky man. I can't find something I dropped right now.
Old 01-20-2020, 01:35 PM
That is super lucky. I could drop a wing in the garage and somehow it would end up in a tree down the street.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 01-20-2020, 03:54 PM
BillL BillL is offline
I hear ya, brother.
Bill
RV-7
Lord Kelvin:
Old 01-20-2020, 10:08 PM
lr172 lr172 is offline
ohhh do I know that feeling
